GM X-Pipe?
Old May 17, 2010 | 01:00 PM
RX-Ben's Avatar
RX-Ben
Default GM X-Pipe?
I read (somewhere) that GM offered an X-pipe to replace the H pipe on the exhaust system. Can anyone confirm this? If so, was it offered pursuant to a TSB? I'm hoping to find a way to get one onto my car under NASA TT rules.
Thanks.
Old May 17, 2010 | 01:34 PM
Haven't heard that one. Only X-pipes I have seen have been aftermarket. If there is one though, hopefully someone will post up the details.
Old May 17, 2010 | 01:37 PM
jrose7004's Avatar
jrose7004
I've never heard that.
Old May 17, 2010 | 01:47 PM
hotwheels57's Avatar
hotwheels57
Did you read that on the internet?
Old May 17, 2010 | 02:47 PM
RX-Ben's Avatar
RX-Ben
Yep. I thought I saw it on cf, but here as well -
http://www.z06vette.com/forums/f4/h-pipe-jingle-119246/
Old May 17, 2010 | 02:56 PM
hotwheels57
Interesting. Have you contacted your local dealer about it? That thread talks about a muffler shop modification to the oem cross over pipe as well as a "replacement" H pipe.
Try this to find GM technical service bulletins. Do a GOOGLE search using "gm tsb search" as keywords. There are multiple hits. Not knowing what year you're specifically looking for, I used "2003 chevrolet corvette" as keywords on this site and found lots to read. You can change the keywords to your specific year...
http://www.tsbsearch.com/Search?KeyW...ndDate=&Page=1
QUOTE:
" Re: H Pipe Jingle
Lemans;
There is a TSB that replaces the entire H-Pipe. I had it done years ago when it came out. Solved jingling problem--for the most part. The problem is that the "H" connector piece on the factory pipe was not the full diameter of the pipe. The TSB addressed this with the replacement H pipe with full internal diameter. Go talk to your local dealer. A search here and on other Vette sites will get you the TSB number.
__________________
Melsy
'03 Red/Mod Red
Old May 18, 2010 | 10:58 PM
RX-Ben's Avatar
RX-Ben
Jingling Noise on Deceleration or Coast Down (Section and Replace Intermediate Exhaust) #04-06-05-006 - (Jun 15, 2004)
Jingling Noise On Deceleration or Coast Down (Section and Replace Intermediate Exhaust)
2002-2004 Chevrolet Corvette
Anyone know what the replacement pipe looks like?
Old May 18, 2010 | 11:52 PM
Texan1Z06's Avatar
Texan1Z06
I have this deceleration rattle/jingle as well. I'm planning to get an aftermarket mid-pipe after I get brakes/rotors and some miscellaneous fluids changed.
Old May 19, 2010 | 08:38 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Had my factory H pipe replaced with the replacement H pipe under warranty. Looks the same to me but did solve the jingle noise. I am one of the few that like the motor boat and popping sounds....plus still unemployed so an X pipe is not gonna happen.
Old May 19, 2010 | 08:58 AM
JWAddington's Avatar
JWAddington
What are the gains of switching out the H-pipe?
Old May 19, 2010 | 09:07 AM
04 commemorative
St. Jude Donor '17
HP...next to nothing
I hear the X pipe reduces the popping and motor boat gurgle.....which I don't mind
Old May 19, 2010 | 01:07 PM
SaberD's Avatar
SaberD
There was a TSB for a jingle noise in the ti mufflers. replacing the h pipe with an x-pipe fixed the issue. The TSB calls for a Corsa x-pipe to be installed. it is not a gm x-pipe.
Old May 19, 2010 | 01:13 PM
RX-Ben's Avatar
RX-Ben
Interesting, does anyone have a pdf of the tsb?
Old May 19, 2010 | 01:16 PM
hotwheels57
GOOGLE "gm tsb 01398" and see what you get...
Old May 19, 2010 | 01:22 PM
RX-Ben's Avatar
RX-Ben
Not a pdf of the tsb.
A bunch of sites list the tsb as existing, that is it.
Old Apr 21, 2011 | 01:17 AM
RX-Ben's Avatar
RX-Ben
Does anyone have access to TSBs? I am still looking for this (gm tsb 01398).
Thanks.
Old Apr 21, 2011 | 06:24 AM
Cybermind's Avatar
Cybermind
I recall reading this TSB.
There is another aspect to this problem that we need to keep in mind. The stock GM H-pipe also has a problem with the tangs that hold it to the hanger springs. Most of the time, they're too long or of unequal length which causes the springs to be loose and rattle. I went with a Corsa x-pipe which not only has a smoother exhaust path but also has shorter tangs. When installed, the hanger springs are much tighter eliminating any chance that they rattle.
To GM X-Pipe?
Old Apr 21, 2011 | 06:47 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Thanks.
Well the only one I can think of is on the C6's but never on the C5's -
Thanks,Matt
Old Apr 21, 2011 | 07:42 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
PM Rick (ragtopws6) he's a GM mechanic.
Old Apr 21, 2011 | 08:11 AM
melvingregory's Avatar
melvingregory
I own 98 vert and a 99 coupe. I went to my local muffler shop and had them modify the H pipe. GM only puts a 3/4" at best hole for the crossover to work. On the 99 the holes were really offset from each other. The shop dropped the exhaust pipes from the headers, took a 2 1/2"hole saw, drilled a hole on the side where the H pipe connected and drilled out the H pipe to the full size. Then they welded the portion they drilled out on the side back on. This elimated the popping sound, and improved performance for $45.
