Interior LED PITA Change!
Old May 18, 2010 | 10:08 PM
wrieck's Avatar
wrieck
Default Interior LED PITA Change!
Okay, replacing lightbulbs is definitely within my "pay grade", but come on...the C5 mirror lights have to be the cheapest, most inaccessible light socket ever invented! I finally completed the installation of those 2 bulbs, and the footwells, license plate lights and the rear cargo area lights...and it does look great...but my gosh could they have made this anymore difficult? Reminded me of replacing the 3rd brake light....ughh!
Tips....mirror lights - cover needle nose pliers with electrical tape to remove and insert the new bulb and use to make the sockets go back into place.... be sure you know which way the LED bulb goes in before securing it! If you blow a fuse...it's #29 in the passenger side inside fuse box.
Footwells - the assemblies pop out with a flat blade screwdriver....easiest replacement.
Back cargo lights - unscrew the plastic cap and work the entire carpeted section out....also easy once you get the section out.
License plate lights - easy to remove - but, just be patient when putting back in and secure one screw and then work the assembly back into postion so the other screw can be replaced.
Repeat after me....Mods are fun...mods are fun...mods are fun!!!!
Old May 18, 2010 | 10:11 PM
wrieck's Avatar
wrieck
Oh, I forgot the step where you come back inside to search the Forum to find out which fuse is for the Interior lights!!...this place rocks!
Old May 18, 2010 | 11:14 PM
VETSTYL's Avatar
VETSTYL
Default The Mirror
I thought the mirror was going to be simple - but it turned into a PITA for me as well
I'm glad to hear it's not just me
Old May 19, 2010 | 12:09 AM
Carcass's Avatar
Carcass
I can do an oil change faster than a rearview bulb change.
PITA is an understatement.
And how about that glovebox light?-I thought the LED was in the socket,then it went "boink" and popped to parts unknown under the dash.(fortunately I had an extra)
and I still have an extra-all I have to do is rip the dash out to find it!
Old May 19, 2010 | 12:33 AM
corvettedaddy11's Avatar
corvettedaddy11
Yea it was a bitch but i won that war also!!!!
Old May 19, 2010 | 03:37 AM
striped91's Avatar
striped91
The rearview mirror light replacement is a peice of cake. Just take the mirror out and do it on the workbench. You guys need to think these things through before you start. You'll catch on after a while.
Old May 19, 2010 | 04:18 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I think the point is, that for a simple bulb swap you shouldn't have to get the part on the operating table...
Old May 19, 2010 | 05:39 AM
Thanks for the tips. Someday I'll tackle the lights in mine and change them to LEDs.
Old May 19, 2010 | 06:31 AM
tstar's Avatar
tstar
Let me know when you're ready Jack, I owe you a favor....
Tim
Old May 19, 2010 | 06:54 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Ohhh! Man that had to be the easiest one I had ever done to the Vette
Thanks,Matt
Old May 20, 2010 | 12:56 PM
wrieck's Avatar
wrieck
Although I don't think we should have to disassemble the car to replace a bulb, you make a good point about the think it through first. I always seem to want to install the latest mod part I get right away...then get frustrated, wait a day and do it the right way!
Old May 20, 2010 | 01:03 PM
Chicago1's Avatar
Chicago1
Maybe I got lucky but I thought the led's where the simplest to change. The rear cargo why would you pull the carpet? The whole light housing pops right out no need to pull the carpet. Takes maybe .5 seconds??
To Interior LED PITA Change!
