So today i started the project of painting my calipers, brackets and rotor hats but i can't break the bolt on the brackets loose. I tried breaker bars, hammering the breaker bar but still nothing these suckers are on there good. Is there anything im missing or can try or are these reverse threads or something like that? Let me know what you guys think. thanks.
The only way I could get mine loose initially was using a 600ft-lb Impact Wrench and the real trick was heating the caliper collar around the bolts with a propane torch - that softens the Locktite they use on the threads. Until I applied heat they would not budge - after heat they came out like butter. They are torqued at about 125 ft-lbs as I recall and have red Locktite on the threads. They are not a "reverse" thread - just in tight.
I used a breaker bar with an impact swivle. I didn't think of the heat idea until I got to the rear where it was a bit tougher to shoe horn in the breaker bar!
You don't need to take them off to paint them if you use artist's brushes. I painted what I could see with them on the car. Got the paint brushes at Home Depot. Cost total about $10 to $15. Only way to know they aren't painted on inside is to lay under the car behind the wheel. I haven't found too many people looking at my car from that angle yet.
On the right side I used my floor jack to 'raise up' the end of the appropriately sized wrench I had on the bolt head. Did the same on the left side just enough to break the bolt loose (because on left side you would actually be tightening the bolt). After just barely moving the bolt, I was able to give the same end of the wrench a couple of good whacks with a big headed hammer which did the trick.
i used a breaker bar and was able to get mine off. they were very difficult i must admit. i got under the rotor, and put my foot on the caliper, and used my leg strength to pull on the breaker bar to turn the bolt.
im not only painting the calipers but rotors too, that rust just annoys the heck out of me. What did you use to clean the calipers? and what kit did you use?
i finally got them off, i went for the propane torch and it was empty so i just got a bigger hammer and went to work, not as smooth as i hoped for but it worked. Do any of you know about the rubber covering on the shaft where the bolts for the calipers go, when taking the shaft out i popped one of the rubber fittings off, do i need to replace it or just pop it back on. Thanks again guys.
I had to use a big breaker bar BUT I did tear my bicep muscle in the process. Live and learn.
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
just push it right back on...there is a small lip that it must sit in. be sure to lube your caliper pins while you are at it...my right side was frozen dry, and I had the warped rotor symptom, but my rotors were fine, which, means only 1 brake shoe side was doing the work. BTW, I had no trouble loosening the bolts everyone is commenting on..just eat some Wheaties first ladies!
Ladies? Hell, your slider pin was dry cuz your Calipers were floppying around and knocked all the grease off em! THAT's why your bolts were so easy to remove!!!!
PB Blaster or penetrating lube. Let it bake awhile, apply breaker bar with pipe attached. Worked well for me.
Didn't need PB Blaster but used a 5' pipe over my 1/2" BREAKER BAR.
They are on TIGHT. GM says replace the bolts. BS. Clean the threads and use red Locktite when reassembling. Used a wire and bristle brush and spray break cleaner to clean the calipers before using brush on Duplicolor caliper paint. Applied several coats and the look like new several years later.
BIGHANK
