Should gauges peg during start up?
Old May 19, 2010 | 03:39 PM
Spot Rot's Avatar
Spot Rot
Default Should gauges peg during start up?
Hi,
I just bought my first C5 (2001) and wondered: Is this is normal?
With my 35th Anniversay Trans Am (1999), when the gauges pegged during start up it meant the battery was on the way out. I'd have the battery tested, it was weak and the gauge pegging went away when a new battery was installed.
Thanks in advance
Old May 19, 2010 | 03:46 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
I think what you're explaining is normal.
You turn the key, the gauges go to the very end and then come back to rest on their normal positions? If so, ya that's normal.
Old May 19, 2010 | 03:50 PM
cdnguyred88's Avatar
cdnguyred88
Old May 19, 2010 | 03:51 PM
YNOT2K's Avatar
YNOT2K
Old May 19, 2010 | 04:11 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Old May 19, 2010 | 04:13 PM
steve8's Avatar
steve8
Not to worry.
Old May 19, 2010 | 04:46 PM
pjbracing's Avatar
pjbracing
Agreed!
Old May 19, 2010 | 05:02 PM
hotwheels57's Avatar
hotwheels57
This is only the second post since I've been here that there's been a consensus...
I believe oem electronic gauges sweep as part as their designed calibration process. At least that's how after market street rod manufacturers explained their products to me.
Old May 19, 2010 | 05:25 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
me too.i use that as a "timer". when the needles have returned to their zero position, i turn the key. starts immediately.
Old May 19, 2010 | 05:43 PM
SCM_Crash's Avatar
SCM_Crash
They're called "Full Sweep" gauges. They do this as a self test. It's perfectly normal.
Old May 19, 2010 | 05:46 PM
dobewillie's Avatar
dobewillie
You bet
Old May 19, 2010 | 05:49 PM
Spot Rot's Avatar
Spot Rot
A consensus? I'm shocked too.
And pleased.
Old May 19, 2010 | 05:50 PM
That's the way they are designed.
Old May 19, 2010 | 07:37 PM
jrose7004's Avatar
jrose7004
It's what you want them to do.
Old May 19, 2010 | 08:08 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Old May 19, 2010 | 08:34 PM
76 VETTE's Avatar
76 VETTE
Mine does it.Just figured it was normal.
Old May 19, 2010 | 08:39 PM
DeltaBravo's Avatar
DeltaBravo
But what's really cool is the "Corvette" by "Chevrolet" on the DIC
Old May 19, 2010 | 09:41 PM
Qcksilverc5's Avatar
Qcksilverc5
Old May 19, 2010 | 09:50 PM
webelo's Avatar
webelo
To Should gauges peg during start up?
