Cruise Control
Old May 21, 2010 | 11:30 PM
WetteVette's Avatar
WetteVette
Default Cruise Control
My cruise control suddenly stopped working. Where should I look first?
Old May 23, 2010 | 11:14 AM
WetteVette's Avatar
WetteVette
After two days, 23 views and no responses, I decided to check my owner's manual (who'd of thought to look there). Page 6-63 to 6-64: Remove the toe board and carpet covering to access the fuse block. Then turn the fuse block door **** and pull the door to access the fuses. Replace the #20 fuse for the cruise control. Problem solved.
Old May 23, 2010 | 11:41 AM
Jet-Jock's Avatar
Jet-Jock
I just saw the post. I would also suggest reviewing the DTCs set in onboard diagnostics.
Old May 23, 2010 | 01:10 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Check fuse #20.
To Cruise Control
