Differential
Old May 26, 2010 | 10:13 AM
Logansar's Avatar
Logansar
Default Differential
How can I check the year of a C5 a differential came out of. Is there a tag or number that gives this away.
Also what are the differences between lets say a 99 - 2000 to a 2003 differential.
I am going from a 2.73 to a 3.42. the 3.42 may be a very low mileage 99 model.
Should there be any issues in this swap?
Sarge
Old May 26, 2010 | 11:31 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I don't believe there is any way to tell the year.
The only issue you will have is that you will need to reprogram all the shoft points for your automatic transmission. You will need some kind of programmer to do this or take it to a tuner shop. Oh yeah - and the silly grin that will be stuck on your face.
Old May 26, 2010 | 01:59 PM
Mike Mercury's Avatar
Mike Mercury
Sarge
Don't forget to swap over the seal plate from your 2.73 to the 3.42 carrier:
http://tim-yvonne.com/mikemercury/342.htm
To Differential
