Cleaning Chassis Aluminum?
Old May 26, 2010 | 03:07 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Cleaning Chassis Aluminum?
Has anyone found a good cleaner to use on the Aluminum under carriage on our C5. I'm not looking to shine it I'm just looking to take the dirt and oxidation off it and make it look factory new again. Thanks!
Old May 26, 2010 | 03:19 PM
memphis_vette's Avatar
memphis_vette
i would like to know as well i have some dirt and grease build up on my chassis due to being DD
Old May 26, 2010 | 03:25 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I used Adams All Purposes Cleaner. I did take it a few steps beyond that and after it was clean, I rubbed it with a real fine steel wool and then applied Mothers Aluminum Polish followed by Adams Metal polish. It takes a lot of time and effort to truly polish it to a real shine, although I do know of a few that have spent the time.
Here is how mine looks.
Old May 26, 2010 | 05:56 PM
jrose7004's Avatar
jrose7004
I use Mothers Wadding polish.
Old May 27, 2010 | 12:56 AM
El original's Avatar
El original
Looks cleaner than "mothers" kitchen....
Old May 27, 2010 | 12:59 AM
corvettedaddy11's Avatar
corvettedaddy11
WOW!!
Old May 27, 2010 | 01:56 AM
thechosenone's Avatar
thechosenone
Shiny!!!!!
Old May 27, 2010 | 08:02 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
This stuff works great:
http://www.detailsupplyonline.com/pr...roducts_id=214
Old May 27, 2010 | 09:54 AM
Fast one's Avatar
Fast one
Buy a gallon of cheap paint thinner that is used to clean paint guns, it removes the tar fast.
Old May 27, 2010 | 10:42 AM
ALLEGRO's Avatar
ALLEGRO
You will also be very surpised at what a ScotchBrite pad will do. I worked over my alterator and bracket.....most think I had it plated.
Good Luck
Old May 27, 2010 | 11:15 AM
bigvx5's Avatar
bigvx5
Good Luck
got any pics?
Old May 27, 2010 | 11:24 AM
Tigershark3's Avatar
Tigershark3
Looks great but I just don't have the time to devote to this much cleaning. My motto is if I can see it I'll try and keep it detailed. Besides when I bought my C5 it already had 65XXX miles of road grit on the bottom.
Old May 27, 2010 | 12:01 PM
NEVERL8C5's Avatar
NEVERL8C5
I used aluminum brightener from napa when i did my trans and dif swap.
I did clean it first with purple power degreaser to get any oily junk off.My car has 148k on the chassis. Don't worry about mileage it will clean up.
Old May 27, 2010 | 05:34 PM
I've used mild steel wool and Mothers Mag Polish on the aluminum pieces before. Haven't invested the time to try and get the stuff really shiny, but it does clean things up a lot.
Old May 27, 2010 | 06:04 PM
Dads C5's Avatar
Dads C5
I used Simple Green and steel wool pads. Then I sprayed with clear coat.
Old May 27, 2010 | 07:57 PM
jrprich's Avatar
jrprich
Which aluminum brightener did you use?
To Cleaning Chassis Aluminum?
