New wheels / non-runflats - Sensor question!
May 30, 2010 | 03:03 AM
Just installed my new wheels and tires (C6 replicas on my C5).
Shop said they couldn't use the existing sensors on my new wheels, so I'm guessing they went with no sensors at all?
At any rate, of course, I now have a "four flat tires" message from my display.
1) Can I simply disable this function?
2) Why would my C5 sensors not work with my C6 wheels?
3) If not, are my C5 sensors worth selling?
Not a fan of the TPMS, as I check my own TP weekly with a LongAcre gauge...
Thanks in advance for any advice!
May 30, 2010 | 09:27 AM
The usual answer will be that the shop is wrong and that the sensors should have fit.
You can hit reset every time you start the car, or I believe it can be programmed out with the correct equipment.
The sensors are probably not worth much. How old are they?
I would want sensors when and if I change wheels.
May 30, 2010 | 09:31 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I would find a new tire shop. They def. fit those wheels!
May 30, 2010 | 09:33 AM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I installed my sensors on my C6 wheels just fine, I have a 2002.
Works great.
You have a 2001 Vert, They should fit just fine.
May 30, 2010 | 09:38 AM
I am a believer in the sensors, They can give you good warring in advance of tire failure.
Go back and have them install them.
May 30, 2010 | 09:39 AM
They should have fit. You have a 2001 so you can have the sensors tuned as not installed. That can only be done on 2001 through 2004 cars. Earlier cars had no provision to tune them out. Need the proper tuning tool to accomplish that.
May 30, 2010 | 09:45 AM
Quote:
Originally Posted by
JW@JWMotoring.com
These are a must-have feature with non-runflats.
May 30, 2010 | 10:26 AM
Mr.Bill
I have C6 ZO6 replicas on my 98 and the sensors are working great.
May 30, 2010 | 11:01 AM
They will fit
May 30, 2010 | 12:24 PM
I have the same wheels on my 99 and they work great
May 30, 2010 | 12:27 PM
The system can be turned off.
May 30, 2010 | 04:01 PM
That's one tire shop I'd cross off my list for the future.
May 30, 2010 | 05:31 PM
St. Jude Donor '06 thru '26
steve8
JW@JWMotoring.com
May 30, 2010 | 08:41 PM
Good info - Thanks all!
I will go back and have them reinstall the sensors. I'll also find out what they meant by "they don't fit".
Just out of curiosity, what's the process for "tuning out" the TPMS function on an '01? Something the dealer has to do, or what?
Thanks again!
May 30, 2010 | 09:10 PM
Might need a Tech II to do it.
May 30, 2010 | 09:27 PM
St. Jude Donor '12
foundvettelifeisgood
You should keep the sensors since you don't want to get stuck with a flat and no spare. Any warning is a good warning. Regular 01-04 sensors fit my C6 Z06 replicas with no issues at all. Find a new shop.
May 30, 2010 | 10:29 PM
Unless they marked the wheel locations on the sensors and you put them back in the proper wheels you may need to relearn them after install.
May 30, 2010 | 10:52 PM
I would think that the sensors would fit the wheel - I agree with finding a different shop and having the sensors reinstalled.
