Suggestions for brake pads?
On my '03, I am running the stock GM pads - no noise from them either.
I would check that, and if true that your hps are squealing, maybe try the c5 z06 pads.
http://www.crcindustries.com/auto/co...x?PN=05016&S=N
All I can say is that it has worked on all three of my cars.
I WILL be putting on ceramic, ultra-low dust pads and I'm looking forward to how clean the front (and rear wheels) wheels will be. I expect braking to be decent as I have had good performance (and clean wheels) on my sport sedan with street ceramic pads.
Simple, It's called BRAKE FADE. I don't track my car, but I do drive a little hard at times. After three hard stops you will have brake fade. As in you are pushing the brake pedal as hard as you can and you are about to hit the car in front of you. Driving into the median because of Ceramic POS pads is no fun. Why would you want these on a Vette?
And they do dust.
I really can't wait for ceramics. The stock pads work well--but hell, low dust is a MUST.
Dusting Characteristics
3. Dust build up on your wheels is caused by the high carbon and metal content of the metallic pad. Because these materials hold static electricity, they are also drawn to the metal in the wheel and brake system, resulting in thick, black buildup.
Ceramic pad compound have no magnetic properties to draw the dust to the wheel, so it is less likely to stick. The dust is also a light gray color instead of black. Any dust that does make it onto the wheel will be less visible.
And they do dust.
As far as ceramic pads dusting--you can't tell bro. The dust is a light gray color instead of black. Any dust that does make it onto the wheel is less visible. Ceramics do not have static electricity to stick the dust to the wheels. The dust on my Hawks street ceramic pads on my G35 have minimal "invisible" dust, even after 2 wks driving so you see nothing but sexy forged 19" Rays wheels--NOT BLACK dust. I speak from experience as I have ceramics on my G35 in my profile pic and they perform GREAT. Read some more about dusting down below under "review."
I am NOT worried about brake fade(friction fade, mechanical fade, or fluid fade). If you think ceramic pads are POS, you in my opinion are ignorant. We are NOT talking about track-use either. Normal to spirited driving on the street.
I have stock cooling ducts to help cool the brakes, new brake fluid to prevent brake-fluid boiling that is worsened with moisture in old brake fluid, and from what I have read ceramic pads are less prone to brake fade due to heat. I do NOT have heavy, sustained braking during my drives so I do NOT fear hitting a car in front of me due to my non-existant fantasy brake fade
Make no mistake, I do let this Z breathe a couple times each time I drive her (she is a beast
), and I have NEVER needed my stock metallic brakes to "save me" from hitting a car in front of me. I hit it and quit it long before I reach traffic in front of me.
I WILL be getting ceramics and there is nothing you can do about it
Washing my car will be a walk in the park and my wheels won't look black after 2 driving days
According to some reviews, metallic pads are more prone to brake fade--see red way down below from a review.
review:
Noise Characteristics
1. Metallic pads are noisy. Brake noise can be traced back to a harmonic vibration caused by movement of the pads due to rotor run out, and the amount of play in the brake mounting hardware.
Ceramic pads, while still affected by this vibration, raise the harmonic noise out of the range of the human ear. It's still there, but we just can't hear it anymore. The softness of the pad also helps absorb vibration much like the old organic compounds. Think of the difference in the sound of a quarter spinning on a table and a rubber washer spinning on the table.
Wear Characteristics
2. Metallic pads eat up rotors. The problem here is caused by the fact that metallic pads are harder than the other pad compounds. When the pad comes into contact with the rotor, the rotor will wear down along with the pads.
Ceramic pads are very soft, and only the pads wear. Because they are also more heat tolerant, they will not wear as fast as the metallic pad compounds.
Heat Characteristics
4. Where the metallic pad shines is in its broad heat range. It functions properly at low temperatures as well as very high temperatures. Metallic pads do tend to hold heat, and brake fade due to fluid boiling still happens.
The ceramic pads' only weakness is low temperature efficiency. They need to be warmed a little during the first few stops. After warm up, they work well. Ceramic pads don't hold heat, so they recover from a hard stop much faster, preventing fluid boiling and brake fade.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
