tps sensors
Old Jun 1, 2010 | 03:58 PM
wolverdick's Avatar
wolverdick
St. Jude Donor '04-'05-'06-'10
Default tps sensors
SO after installing new rims last year, and then finally getting around to pulling the tps off the old stock rims, I was getting ready to reinstall the tps's on the new rims.
after reading a thread here on the forum, I can see that my tps's are from 11/96, the original sensors that came with the car.
what I am wondering; is there a way to replace the batteries on these?
They worked fine before but they are probably on their last legs.
If not, can anyone recommend a good vendor to purchase new ones?
Old Jun 1, 2010 | 04:12 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
I bought new TPMS from the Tire Rack
LUKE (EXT.362) at 888-981-3953 or email luke@tirerack.com
They were $38 each. The price was the best I have seen, however I bought new wheels and tires also.
Old Jun 1, 2010 | 04:15 PM
Bills03Coupe's Avatar
Bills03Coupe
Sensors for the 97 C5 are more expensive, I believe around 80 to 90 buck a piece!
Old Jun 1, 2010 | 04:20 PM
wolverdick's Avatar
wolverdick
Is there something that makes the 97 sensors different??
and I am guessing from the lack of comments, and the completely molded nature of these things, that replacing the batteries is not an option.
Old Jun 1, 2010 | 04:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Yep. The system was different but I don't remember the date they changed. They newer ones are less expensive but are they are not interchangeable.
You can replace them. Do a search in the Tech section. Not the easiest procedure but it works.
Old Jun 1, 2010 | 04:30 PM
Bills03Coupe
The early cars had a different frequency and the receivers will not work with newer (01 and up) sensor. Conversely, newer sensors will not work in the early cars. I believe you can replace the batteries in the early sensors, but not the newer style.
Old Jun 1, 2010 | 04:47 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The TPS for '97-'00 are the same and very expensive. The '01-'04 sensors are much less expensive but are not interchangeable unless you change the receiver and your FOBs.
If you are thinking of changing out all four you may want to consider the '01-'04 route. You can buy all four TPS, the receiver and a FOB for as much or less than four '97-'00 TPS.
The batteries can be replaced in your sensors but it is quite a job. You will find good instructions here:
http://forums.corvetteforum.com/c5-t...-tutorial.html
If you want to do the upgrade this should help:
http://forums.corvetteforum.com/c5-t...aded-tpms.html
Old Jun 1, 2010 | 04:49 PM
Amherst's Avatar
Amherst
Some dude has a pretty good tutorial on battery replacement posted on Youtube too:
http://www.youtube.com/watch?v=QjrT7WBG6U8
Old Jun 1, 2010 | 04:52 PM
jrose7004's Avatar
jrose7004
Forum member Corvette Don does battery replacements.
Old Jun 1, 2010 | 05:21 PM
Mark C5's Avatar
Mark C5
Another option if you don't care about sensors:
http://www.dragtimes.com/parts/1997-...460900273.html
Old Jun 1, 2010 | 05:43 PM
Bimmervet's Avatar
Bimmervet
The sensors are for a 1999 Corvette
Old Jun 1, 2010 | 06:03 PM
Mark C5's Avatar
Mark C5
I just got off the phone with Gary at Tire Rack. The current price for '97-'00 sensors is $63.00 each, which is a very good price.
Old Jun 1, 2010 | 06:10 PM
wolverdick's Avatar
wolverdick
Thanks for all the great info.
I am going to give a call to the local corvette shop and see what prices he has, since I will be going there to get them installed anyway. I'm sure he cant beat that Tire Rack price though...
The sad part is I am doing this to get the car in tip top shape for sale in the next week or so. I will be listing it exclusively here on the forum first. I hate to let her go, but times being what they are, I really have to make the choice to sell her.
Old Jun 1, 2010 | 06:18 PM
Mark C5's Avatar
Mark C5
Sorry to hear you have to let it go. Good luck with the sale.
Old Jun 8, 2010 | 05:23 PM
blackula 99's Avatar
blackula 99
I do tps sensors also....very easy.....looking at roughly 11.00 a battery plus labor...have already done all four on my car
To tps sensors
