need some help
Old Jun 6, 2010 | 04:10 PM
talon46's Avatar
talon46
Default need some help
I have photos of my front end up off of the ground to show what 17 k miles does to your tires after a lowering kit is done and no front end alignment, I said I would, but there is no good way to get them on here. Advice and help would be appreciated, I bought the car and did not know it was lowered, costly lack of knowledge two front tires alignment and oil change 680.00 of that 521 for the front michelin PS2's AS's. it will cost me another 700 to do the rears when I can afford to do them. They still have enough tread to use them awhile longer.
Old Jun 6, 2010 | 06:44 PM
Jistari's Avatar
Jistari
That the part you need the help with (the pics) ?
If so:
Go here http://photobucket.com/
Register on the Photobucket site (you will need a working email address, but it is free otherwise).
Upload the pics from your computer to your photobucket account.
Open a new tab or browser window (keeping your photobucket account with the pics in it open in a seperate tab or window) and log on to Corvette Forum.
Come back to this post and click reply.
Type your text and when you want to insert a pic, go over to the other tab or window with your photobucket account and as you mouse over the pic, a selection will pop up under it with several links. You want to hilight the info in the link marked IMG Code by left clicking it, then right click and select copy.
Go back to the tab or window that you have open with your post here on CF and click the Insert Image icon (bottom row fifth one from the right (looks like a landscape pic, mountains and sun . . .)
In the box that opens, right click on the http: and select paste (it will paste the link to the pic you copied from the tab or window logged in to your photobucket account), click ok.
Done.
When you finish the post (submit reply) your pic will be viewable from the info you copied in.
Good luck.
BTW this is all in the sticky at the top of the forum about posting pics
Old Jun 6, 2010 | 09:46 PM
talon46's Avatar
talon46
Default thanks tommorrow when I have some time
I will get them posted.
To need some help
