Sticking clutch
The problem is some times when it sticks the clutch disengages and there is power to the wheels. Bad at a stop sign or red light! The only way to get it out of gear is turn off the engine and restart. Once the car is in another ger other than low or reverse I haven't had the problem.
If changing fluid doesn't fix the problem, what does installing a new slave cost and should the master also be changed?
Thanks for the help,
thom
I would suggest changing out the master to an OEM first, since it can be done within 45 mins - 1 hour and it is not that expensive and a DIY job. See if this solves your problem. I had a clutch change on my old C5 and the shop did everything except the master. I pick up the car and the pedal was stuck to the floor. Changed the master myself and it solved the issue.
Hope this helps and good luck.
