Stock tune?????
Old Jun 9, 2010 | 04:43 PM
03z06BLK's Avatar
03z06BLK
Default Stock tune?????
Hey guys I am looking at a z06 in texas I am from Colorado and I know it FAILED EMISSION INSPECTIONFAILED SAFETY INSPECTION. I asked why guys said because never gets drove and the battery was shot I guess. So here is the Vin if it has the stock tune I know it has warranty 1G1YY26E075136385 thanks guys. it is a 07 Z. guys said it has a stock tune on it.
Old Jun 9, 2010 | 05:20 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I'm not entirely sure (heck, I'm not at all sure) of what you're asking here. The post kinda rambles.
But,
You should be asking in the C6 section since this is a C6.
The battery being dead is . That is not why it failed inspection.
Get the inspection sheet from the seller. It will say WHY it failed.
If it is under warranty, tell the seller to get it fixed, pass inspection, and give you a call back.
Good luck
Old Jun 9, 2010 | 05:26 PM
Tech's Avatar
Tech
But,
Good luck
He's right on the first account. Not necessarily on the 2nd. There are emissions readiness monitors that have to run, and complete successfully before a car will pass the OBD2 plug-in test. The monitors run under various driving conditions, so it's possible the guy didn't drive the car enough before taking it in.
Old Jun 9, 2010 | 05:37 PM
chris723@ptd.net's Avatar
chris723@ptd.net
if he cleared all the codes in the DIC 4 some reson he will have to drive it 50 to 100 miles i belive
Old Jun 9, 2010 | 06:13 PM
Tech's Avatar
Tech
That's basically what I'm talking about. However, the drive time is really not dependent on mileage. There are specific driving conditions that have to be met.
Old Jun 9, 2010 | 07:17 PM
n8dogg's Avatar
n8dogg
But,
Good luck
A dead or removed battery CAN cause emissions failures. This is because it resets all of the emissions monitors.
Each monitor has its own set of criteria that has to be met in order for it to pass. For example the catalyst might require a cold engine start, engine must continue running until running temperature, travel at 55mph for a minimum of 15 miles, throttle position of 0-60%, open loop status...etc...
So in other words, just drive the dang thing for a couple hundred miles.
Can't clear codes in a C6 DIC
Yup, like I said above, each monitor has its own requirements. Best thing to do is drive it for a few days or couple hundred miles. You can also pick up mini scanners from Mac or Matco that list the monitors and will tell you if they are passed or not.
In NYS 96-00 cars can have 2 monitors not ready, and 01+ can have 1 not ready.
Old Jun 11, 2010 | 10:56 PM
Pchild's Avatar
Pchild
I have been told that you have to go through 7 ignition cycles before it will pass, by a local corvette dealership. I have no official document to back that up.
Old Jun 28, 2010 | 11:35 AM
Tech's Avatar
Tech
It is not that simple, my friend.
http://www.obdii.com/drivecycle.html
http://www.obd-codes.com/trouble_cod...ving-cycle.php
http://www.lyberty.com/car/drive-cycle.html
Old Jun 28, 2010 | 03:06 PM
Pchild's Avatar
Pchild
Thanks for the info. Guess the guy at the dealership didn't know what he was talking about eh?
Old Jun 28, 2010 | 03:49 PM
warlock007's Avatar
warlock007
safety inspection failures are normally brakes, E-brake failures, tires, brake fluid leaks anything that can directly cause a loss of control or the failure to control.
Old Jun 28, 2010 | 04:27 PM
Tech's Avatar
Tech
Or, perhaps he was just lazy and didn't want to explain it all to you.
To Stock tune?????
