painted calipers red?
Old Jun 10, 2010 | 12:31 PM
KillerC5's Avatar
KillerC5
Default painted calipers red?
i'am thinking of painting my calipers red..at the moment they are the stock grey color..anyone have pics of theres painted? i want to paint it red and keep the corvette lettering white
Old Jun 10, 2010 | 01:42 PM
RedZMonte's Avatar
RedZMonte
like the Stock C5Z caliper? they look nice. Red Cliper, black bracket and silver lettering
Old Jun 10, 2010 | 01:45 PM
shadeshift's Avatar
shadeshift
Click Here: C5 Red Caliper Picture
Old Jun 10, 2010 | 02:04 PM
jrose7004's Avatar
jrose7004
Old Jun 10, 2010 | 03:48 PM
WRTHW8's Avatar
WRTHW8
I can't post a pic but I could email you one. I took mine off and painted them red then took a sanding block and sanded the red off the letters. I think it looks good.
904pizza's Avatar
904pizza
Originally Posted by shadeshift;
Exactly!!
Old Jun 10, 2010 | 04:04 PM
Daw9-02Vert's Avatar
Daw9-02Vert
Painted calipers-stock -wheels
Lot's of DIY threads! Good luck.
Old Jun 10, 2010 | 04:45 PM
KenShores's Avatar
KenShores
I just did mine black. I got a kit with the hardener type paint that you mix together. It is good stuff and there is enough to do a lot of painting. Two coats or more, but it does start to thicken. Because of the hardener, you will need to paint all of your calipers/coats in a short time. They want 24 hours drying time before you use the car again. Minimum two before putting wheels back on. Have some lights available so you can see what your doing. I have some halogens, this got hot quick.
For me this was a lot of work for so little gain, but still fun in the long run. I did have to laugh at myself a few times for doing this.
I did front and rears so the car is up and all four wheels off. Forget about trying to paint between the letters. Paint all over them. Make sure you don't paint any rubber parts. Let dry over night at least. Get some fine sandpaper/emery cloth and a flat block that you can handle easy. I used an old cassette case with emery cloth to sand the paint off the letters, exposing the metal. I used the small edge. This is the real fun, as you want to make sure you don't hit areas that you want to keep the paint on. By this time your paint mix has dried. No do overs. No way would I go back to paint the letters white or any color.
While your there you may as well clean the wheel wells and suspension parts that you want cleaned. I used a black sealer (turtle wax black chrome) on inner wheel wells that stays very dark makes it easy to clean off with just a hose. And you may as well polish up those wheels while your letting the paint dry.
Old Jun 10, 2010 | 05:52 PM
BAD-C5's Avatar
BAD-C5
Old Jun 10, 2010 | 05:54 PM
Go for the red - it will look great on your car.
Old Jun 10, 2010 | 06:39 PM
rickko's Avatar
rickko
Old Jun 10, 2010 | 06:43 PM
91LSMAN's Avatar
91LSMAN
Red is good.
Old Jun 10, 2010 | 07:09 PM
benjiusn's Avatar
benjiusn
Old Jun 10, 2010 | 07:20 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
I can't wait to use that on my coworkers
Old Jun 10, 2010 | 07:48 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Originally Posted by BAD-C5
That looks Where did you get your rotors from?
Old Jun 10, 2010 | 07:53 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Do it. Red matches everything. Here are a couple pics of mine...
Old Jun 10, 2010 | 07:54 PM
WildTurkey's Avatar
WildTurkey
Yep - RED is the way to go!!
To painted calipers red?
Old Jun 10, 2010 | 09:46 PM
4U2ENVY's Avatar
4U2ENVY
From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
Old Jun 10, 2010 | 09:48 PM
kenc5's Avatar
kenc5
Did mine in LeMans Blue. Car is LMB.
Old Jun 10, 2010 | 11:06 PM
Sargechris's Avatar
Sargechris
Tires look Great also!! I just got a set of Proxes T1R's and putting them on as soon as my new TPMS sensors arrive..
