Headers Install.....how much to pay?
Old Jun 12, 2010 | 01:55 PM
jeterarodyks's Avatar
jeterarodyks
Default Headers Install.....how much to pay?
Can someone tell me ballpark figure on what it would cost to install headers??? (yes i know barring fit issues etc..just general idea is all) thanks alot!
Old Jun 12, 2010 | 02:25 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
paid $400 for my header install.
Old Jun 12, 2010 | 02:29 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Mine was free!!! DIY its really not hard. It can be done on jack stands.
Old Jun 12, 2010 | 02:38 PM
Edmond's Avatar
Edmond
That seems like a pretty good deal.
OP, if you have jack stands, do it yourself and use the money you save for another mod like new wires/plugs. You'll probably end up tearing the old wires up.
My suggestion is to get new bolts for the headers.
Old Jun 12, 2010 | 03:00 PM
Fast Cop's Avatar
Fast Cop
This is a fairly easy DIY. If your car is not a DD and you have the time a DIY is the way to go. I installed a set of LG Long Tube Headers, HF Cats, X-Pipe and a Z06 Ti catback. It was not that hard and I did it in one weekend.
Good luck with whatever you do.
Old Jun 12, 2010 | 03:04 PM
Edmond's Avatar
Edmond
As for the original question, I see most places are in the $400-500 range. Way too much, IMO.
You will have to swing the alternator out of the way as well as removing the coil packs.
The bolts underneath the manifolds will probably end up breaking due to being rusted.
Having the exhaust system is also a good time to put in a tunnel plate if you have considered that.
Old Jun 12, 2010 | 03:05 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I agree with the DIY if you have a free weekend, a buddy to help out and a few beers lying around. What size/brand are we talking about? I hear the 1-3/4" headers are more likely to fit without having to move the engine, than the 1-7/8" ones. I was able to snake my 1-3/4" LG Streets in but it was pretty dang tight. But all in all, it wasn't really "hard". It just took some time, and my bro and I had fun doing it.
FYI there is a nice writeup here, which I used over the provided instructions. It covered about 90% of what I needed to know and the rest I just figured out along the way.
http://www.cajundude.com/longtubes.htm
Be sure to get the F-body header gaskets, they have round ports instead of oval ones that the Vette gaskets have. You can see part numbers and comparison pics in the above link.
Old Jun 12, 2010 | 03:19 PM
In this area, I have been quoted approximately $400 for a LT header install.
Old Jun 12, 2010 | 03:39 PM
Black-Sheep's Avatar
Black-Sheep
If you are somewhere in the Northeast, you can get them installed for free at Carlisle in 2 months. Last year, I was qutoed $1800 for AR long tubes with cats installed at the American Racing tent. I ran out of time due to the weather. I plan on getting them done this year though.
Old Jun 12, 2010 | 04:47 PM
jellis's Avatar
jellis
DIY, there is no substitute for learning to work on your own car, you'll learn many things doing it yourself. the satisfaction of DIY is great as well.
even if you have plenty of money, the experience is price less.
Old Jun 12, 2010 | 05:13 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Don't pay more than 400. If you are not comfortable doing it yourself, no worries. Don't let folks talk you into a DIY... they are right, from a tech standpoint, yea it is straight forward bolt on..but if you are not that agile with tools, it will not be that easy.
I did mine myself with the help of a friend who is a mechanic, we had a lift and shop tools.. I can't imagine trying to do it on a garage floor on jack stands...granted its not terrible but getting the car high enough off the car is a project in and of itself.
Old Jun 12, 2010 | 11:27 PM
SargeZ06's Avatar
SargeZ06
Couple hundred.
If they are Kooks then it's a couple thousand...
Old Jun 12, 2010 | 11:34 PM
Bigcountry7's Avatar
Bigcountry7
Originally Posted by SargeZ06
Couple hundred.
Why so much for kooks? If you were serious.
Old Jun 12, 2010 | 11:40 PM
thechosenone's Avatar
thechosenone
DIY.......Its more fun!
Old Jun 12, 2010 | 11:43 PM
Superman09's Avatar
0Superman09
Former Vendor
DIY, the headers you bought are a piece of cake to install
Old Jun 13, 2010 | 05:01 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
Definitely get an aftermarket tunnel plate as well.
Old Jun 13, 2010 | 09:40 AM
Tom Keitzer's Avatar
Tom Keitzer
Default Header Install
I just had a set of Kooks installed along with a new x-pipe which did away with the catalytic converters. Cost me $600 which included better gaskets and non-backout manifold bolts. I probably could have done it myself on jack stands but I like my knuckles the way they are. Good luck.
To Headers Install.....how much to pay?
Old Jun 13, 2010 | 01:37 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
$300 to $400 and then get a tune for the best results
Old Jun 13, 2010 | 03:53 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
If you move ahead with the hedders make sure you put a heat shield around the starter motor. iF YOUR STARTER GOES OUT DUE TO THE EXTRA HEAT YOU WILL HAVE TO PULL THE EXHAUST ON ONE SIDE TO REPLACE THE STARTER
Old Jun 13, 2010 | 05:06 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Any pics of this? What type of heat shield did you use??
