Front blinker question WITH picture
Old Jun 13, 2010 | 07:27 PM
iceman82nd's Avatar
iceman82nd
Default Front blinker question WITH picture
I've read up and trying to replace the front right blinker bulb. Got the orange bulb and can get access from the headlight (as you can see from the picture) My only problem is where is the orange bulb currently located and how do i remove. I'm not sure how to remove (whether it be twist and pull/unscrew...). Hope to hear back soon!
Thanks,
Joe
Old Jun 13, 2010 | 07:30 PM
iceman82nd's Avatar
iceman82nd
If there is a tab that needs to be pressed to unlock and release the bulb where is it and what type of tab should I be pressing to disengage this bulb.
Old Jun 13, 2010 | 07:33 PM
jrose7004's Avatar
jrose7004
There is a access panel underneeth that might be easier to get into.
Old Jun 13, 2010 | 07:37 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Push in and twist counter clockwise - when you re-install it, it can only go in one way (it has a keyway to it)
Line yourself up with where it is at on the outside of the Vette and reach in and you'll have it, if not lift the Vette and remove the triangular shield and access it from the bottom (better view too)
Thanks,Matt
Old Jun 13, 2010 | 07:40 PM
iceman82nd's Avatar
iceman82nd
Ok i found the light and the tab, when i try and twist im not sure if im supposed to twist WITH the electrical tab or something else is supposed to twist. BTW how much strenght was needed to twist it - I tried to but wasnt sure if i was supposed to put my hulk strenght into it or not..
Thanks,
Joe
Old Jun 13, 2010 | 07:48 PM
iceman82nd's Avatar
iceman82nd
I can get in there and grab the light and get it fine, just when i get ahold and push the tab in and then twist the bottom of the **** where the wires go into the base it just wont crank counter-clockwise.
To Front blinker question WITH picture
