[Z06] Intro/SP500 showoff/lowering question thread
Name's John. Picked up an '02 Z06 a couple months ago now. Bought it with 28k miles! Last owner threw a Flowmaster axle back on it (which will get changed out) and added some minor things like a short antenna, C6Z shifter, partition, etc.
I added 20% tint and a Vararam B-2 two weeks ago; threw it on the dyno and made 361whp/355wtq. on a dynojet - seems to be spot on average.
Fast forward to this weekend and I found my dream set of wheels locally on craigslist for a spectacular price and just couldn't pass it up. CCW SP500s - 18x10 (275/30), 19x11.5 (305/30) wrapped in Nitto Invos. Don't mind the junk pics - I'll get better ones soon.
Before all this I lowered the car using C6 front bolts, and the WCC rears. I maxed out the fronts and settled the rears with 10 threads showing. Looking at others' cars, their front looks so much lower than mine even when using the same bolts maxed out like mine. I tried jacking up the a-arm to possibly gain more clearance, but it wouldn't budge. Slipped my finger in and all that's between the a-arm and leaf spring is the C6 bolt head.
What could be causing this? Please any help would be appreciated.
Thanks and
Thanks!
Take Mark's (Toque's) for example (hoping it's ok to reference):
Now, I did notice that mine seemed to settle a bit today - so I'll take pictures tomorrow and contrast it against my first posted pics and his again. However, in looking at his car more specifically, and the angles he shot his car at, I'm drawing 2 conclusions:
1.) Most of the pics I've seen when judging this is that his are mostly from the rear - which perceives the front wheel gap to look a bit lower than it really is. This is one of the few of the front that will help me gauge better.
2.) His wheels are 19". He's running a 275/30/19. I'm running a 275/35/18. My circumference is about 7mm greater, and my diameter is about 2mm greater. So, if I'm thinking correctly, I'll have a 2mm LARGER wheel gap. Is that even going to be noticeable? Doubtful. Hmm..kinda shot down that one.
Maybe I'm going crazy....it's possible at this point.
Take that into perspective, but I'd say it's a 1/4" thick from what I remember. I just looked at the Zip ones, and without seeing them side by side I can tell the C6 ones are ever so slightly thicker, but certainly not enough to compensate for the amount of wheelgap I have. Ugh...so frustrating.
When you lower the car this far it becomes unsafe at high speed especially on the freeway. Mine only had about an 1" of shock travel left and the backend would BOTTOM out and bounce around when the road got uneven - coilovers give you the stance, look and handling these NIBBLE cars were intended to have at higher speeds and are way SAFER - spend your $$$ wisely What ever you choose to do - get a 4 wheel alignment afterwards
This is the front of a 03 Z , w/out adjusters. As stated before, you need to go on some bumpy roads, not free way to get car to completly settle. Reason for backing adjuster bolt back a half turn is so that the bolt won't become bonded to the bottom of the spring. Making it much easier to readjust or remove.
Someone else suggested could it be possible the shock bushing at the top of the shock be holding things up too? I've never heard anyone have that issue before, but it makes sense that it could at least be possible.
Thanks for the reference.
Here's Mark's (Toque's) again - max lowered on C6 front bolts using a 275/30/19 tire:
Here's a car with NO BOLTS - unsure on tire:
Here's mine - max lowered on C6 bolts using a 275/35/18 tire:
...and just because I want to show off my new wheels:
So what do you guys think? Everything seem pretty normal now or do I have some wrenching to do?
But I have since installed PFADT coilovers - this is what you really need to do
