The LARGE CALIPER MOUNTING BOLTS are torqued to 125 ft# not the small ones (pads)
Originally Posted by reactor2
One more thing, are they supposed to be torqued to 125 ft/lbs?
The large bolts which hold the caliper brackets on are red locktited and torqued to 125 ft#. Don't even think of tightning the small ones which hold the pads on to that level of torque or you will be looking for broken bolt extractors.
The smaller 2 bolts for ea side that is used to hold the caliper to the bracket, and must be removed to remove the caliper is #14067559 Tighten to 23 lb. ft.
The large bolts that hold the caliper bracket is #14084051. Tighten to 125.lb.ft. In order to remove the rotors, you must remove these bolts.
