[Z06] A/C Refrigerant Gone?
Old Jun 15, 2010 | 01:03 PM
ffranklin's Avatar
ffranklin
Cruising
Default A/C Refrigerant Gone?
When I hit the "AC" button the light comes on in the button for 3 seconds and then goes out. The inner belt is turning but the compressor clutch never engages - the compressor outer plate does rotate freely. I believe there has to be pressure in the system for the compressor to kick in, yes? Sound like I have a leak? Z has 92,000 on it.
Thanks.
Old Jun 15, 2010 | 05:59 PM
H8TOBL8's Avatar
H8TOBL8
My 03 Z only had 33k when it started leaking...
Old Jun 16, 2010 | 10:04 PM
Its Bruce's Avatar
Its Bruce
Check for pressure (use search function for howto). If the pressure is there, check fuses and the small gray relay in the fusebox under the hood. I had to swap my relay with the horn for it to work. Of course now my horn doesn't work.
To A/C Refrigerant Gone?
