diagnostics fail
Old Jun 19, 2010 | 07:21 AM
shell's Avatar
shell
4th Gear
Default diagnostics fail
while driving i lose all my gauges and radio and then get check messages for everything if i shut the car off it clears until next time can anyone help
Old Jun 19, 2010 | 07:29 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It would help if you listed the codes. Sounds like a com error.
Old Jun 19, 2010 | 08:51 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Shell,
You sound like you might be experiencing a ground issue or at the least a Connection Plug/Harness is loose. It can possibly be at the Instrument Panel or at the BCM (Passenger footwel, behind the panel under the carpet)
Look here in the Tech section under the ELECTRICAL Sticky
http://forums.corvetteforum.com/c5-t...tion-long.html
You will learn alot about your Vette here and if you need to contact Bill Curlee - he is the resident guru on Electrical Issues
Thanks,Matt
Old Jun 19, 2010 | 10:35 AM
shell's Avatar
shell
4th Gear
Default diagnostic fail issue
thanks matt
Originally Posted by madmatt9471
Shell,
Thanks,Matt
Old Jun 19, 2010 | 11:55 AM
shell's Avatar
shell
4th Gear
thanks again matt
Old Jun 19, 2010 | 08:20 PM
backnblack2003z06's Avatar
backnblack2003z06
Originally Posted by 8VETTE7
I'd start by checking the wires inside the rubber accordian tube between the body and door. More here:
http://forums.corvetteforum.com/c5-t...n-long-32.html
Then go to post #640.
Agree 100%, check there first, seen it dozens of times all with the same issues you have.
To diagnostics fail
