Sagging Headliner....
Old Jun 19, 2010 | 03:18 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Default Sagging Headliner....
My 2001 C5 headliner is sagging. I've searched the forum but didn't find much on a fix and/or mod. Has anyone ran into this problem? If so, what did you do. I've seen the pop-in headliners to reduce interior heat, which is an option.
Old Jun 19, 2010 | 03:22 PM
socalman's Avatar
socalman
St. Jude Donor '10
3M 77 Spray adhesive? remove a trim piece, pull down, spray roof and cloth, press from the center out.
Old Jun 19, 2010 | 03:31 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
Will the spray adhesive soak through the liner? Also, will it resist the CA 100+ degree temperatures?
Just noticed you're in CA....Do you have experience with this fix?
Old Apr 22, 2011 | 02:15 AM
Black$heep's Avatar
Black$heep
http://forums.corvetteforum.com/c5-g...cha-think.html
To Sagging Headliner....
