electronics issues car went nuts today...Help! :(
At this point i know something is up but it seems like everything has settled down. I knew I was going to have to look into this on Monday but at the moment it was like nothing ever happened. I had two stops I had to make before I went in. Made the first one came out...everything was fine. Decide ok. let me drop this stuff off and I'll take it in. Came out..BANG it's the steering lock thing...turn the key..nothing. Everything inside the car is working and normal but it wouldn't do a thing, not a sound. Now before you yell at me I had the by pass put on it last year when it wouldn't start like this and was told that would fix that problem and the car hasn't ever acted to till today.
So...has anyone else seen or heard of anything like this?
Should I get another by pass for it?
Was it the bump in the pot hold that knocked something goofy?
I ended out leaving it at a friends and took the train home. Just didn't trust it.
Further, all the symptoms you are describing match to a T those of the serial buss wire, in the door rubber accordian tube between the door and body, shorting to ground. Read the following (with pictures):
http://forums.corvetteforum.com/c5-t...n-long-32.html
Then go to post #640.
Easy repair. get yourself some liquid electrical tape. Available at most parts stores.
How old is the battery? Could it be going? What does the DIC read for the battery voltage? S/B between ~13.3v to ~14.2v (when running). Could the jolt from hitting the pot hole caused one of the battery cables to loosen?
Good Luck! These kind of problems can be very frustrating...
1. Check the connections in the accordian covers inside the door hinge. Very common for one of the wires in the back of the connection to lose its plastic cover. Causes all sorts of weird gremlins including traction control/ABS.
2. Check the wiring harness under the battery. Bought a car that must have had a previous leaking battery (had new one at purchase). Cuased many electrical gremlins including reduced engine power and I eventually developed an occasional engine misfire whenever it rained.
3. Have heard of issues with the grounds.
Good luck. You can also shoot Bill Curlee a PM or check his posts. The man is an electrical genious when it comes to the C5. Nice guy too.
