Re-route coolant line
Old Jun 20, 2010 | 08:32 AM
Michael99Vette's Avatar
Michael99Vette
Default Re-route coolant line
I just purchased a KaTech ported throttle body. My mechanic said to re-route the coolant line to bypass the throttle body.
Does anyone make a nice looking kit for this, or will I have to cobble something up?
Sincerely,
Mike
Old Jun 20, 2010 | 09:42 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
Sincerely,
Mike
We have a kit for you!
http://www.corvettemods.com/servlet/...-bypass/Detail
Old Jun 20, 2010 | 10:39 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sincerely,
Mike
All you need to do is go to a parts house and get 2 clamps and a barbed hose connector, Cost at most is like 5 bucks. As far as the mod goes you really won't notice any difference with or without it.
jmo.
Mr.Bill
Old Jun 20, 2010 | 10:44 AM
0corvettemods1
Former Vendor
jmo.
Mr.Bill
Most hardware stores only have brass barbs. These can carrode and contaminate the coolant. We use aluminium like the engine block.
Old Jun 20, 2010 | 10:49 AM
8VETTE7's Avatar
8VETTE7
I used the plastic Tee from a flush kit and a pair of stainless hose clamps. Had the Tee left over and sitting in my tool box for years. Finally put it to use..........
Old Jun 20, 2010 | 01:57 PM
paullywalnuts's Avatar
paullywalnuts
you can get those parts from that same kit at any auto parts store..problem is keeping it clear of the pulley. Very tight clearance unless you add alot more hose to stay clear of the pulley under the TB.
Old Jun 20, 2010 | 02:19 PM
blkvette98's Avatar
blkvette98
Default Coolant bypass kit
I have a new kit with the aluminum tube and connecters from West Coast Corvette. $12 bucks shipped if your in the lower 48.
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Very simple to DIY. Dont spend $20 for $5 worth of parts. Its one of those mods thats really doesnt help much, but at the same time doesnt hurt.
Old Jun 20, 2010 | 03:29 PM
Last C5's Avatar
Last C5
One piece of hose and a push pin hose holder does it. Run the hose from the radiator along the to of the fan shroud with a hose holder then over to the outlet on the manifold. Clean, out of the way of everything, and only two connections. You'll probably even find a small hole in the shroud to plug the hose holder in. At least there was one on my 01Z.
Old Jun 20, 2010 | 03:38 PM
futuretech's Avatar
futuretech
I used 1/4 fuel line and ran it from the manifold to the radiator. Had to remove the radiator support to R/R the hose. very neat. Two clamps.
To Re-route coolant line
