gauge issue
Old Jun 21, 2010 | 08:01 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default gauge issue
just bought a 2000 corvette
was driving after filling car up the gauge was reading full about 20 min later check gauges light came on and the gauge was on empty please help
thankyou
jason
Old Jun 21, 2010 | 08:07 PM
jrose7004's Avatar
jrose7004
Try a couple bottles of Techron with the next couple of fillups and see if it helps.
Old Jun 21, 2010 | 08:09 PM
didntdoit11
St. Jude Donor '12
ok thank you what would be causing this problem
and thanks again,,,,where would i get said product locol autoparts store
Old Jun 21, 2010 | 08:11 PM
atmsrus1's Avatar
atmsrus1
This is a common problem with the C5, use the techron as stated above and it will help some but doubt it will totally resolve the issue. I have been adding it to mine about every other tank and it has helped a lot, don't see it quite as much as I did.
Advanced Auto has specials all the time and so does AutoZone.
Old Jun 21, 2010 | 08:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is a common issue with the C5, What happens is the sensors in the tanks get a sulfur build-up on them and they quit working, I only use Chevron fuel because it had tecrhon in it. If yours isn't too far gone you can try what JRose said to do, And if the Techron corrects it stick with good gas like Chevron or Texaco.
Bill
If you use Chevron or Texaco it has Techron in it.
Old Jun 21, 2010 | 08:13 PM
jon c's Avatar
jon c
I run about 3 btles of techron a year thru mine and I havent seen the gauge issue since I started it and yes it is a local auto parts store item
Old Jun 21, 2010 | 08:14 PM
brightonvette's Avatar
brightonvette
Common problem. Use premium fuel and add a few cans of fuel system cleaner to the gas tank the next few fill-ups. The guys here on the forum will have a number of recommendations as to brand. I use Techron, but others have used different products with good success. Issue will likely clear up after 2-4 tanks. If not, you have a bigger problem with fuel sending unit ect.
Old Jun 21, 2010 | 08:15 PM
didntdoit11
St. Jude Donor '12
you guys rock thanks so much
scared the s.... out of me when i say that
Old Jun 21, 2010 | 08:24 PM
brightonvette
I see you live in Westland MI, check out the Forum area on local events and join us at the next Motor City Vettes gathering at Hooters in Troy on 6/30.
Old Jun 21, 2010 | 11:00 PM
Sulfur deposits on the fuel sending units can cause erratic gauge behavior. Adding Techron to the gas can help remove the deposits and hopefully get the gauge working correctly again.
To gauge issue
