Losing oil
Old Jun 22, 2010 | 09:42 PM
corvettekid1973's Avatar
corvettekid1973
Default Losing oil
I've had my 01 Z for about 2 years And it uses oil, not alot but enough that I may add a quart every 4 or 5 months. It doesn't smoke and runs great. I've heard those ls motor have high crank case pressures so I'm guessing that may be part of it! Any ideas????
Old Jun 22, 2010 | 09:56 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is a known issue that some C5s go through oil, It was a ring issue in the motor, It is mostly when the car is driven hard.
Old Jun 22, 2010 | 10:01 PM
corvettekid1973
Yeah that's about how it is, I don't drive it like I stole it but I do like to wind the gears on ocassion thanks
Old Jun 22, 2010 | 10:21 PM
jlbruggeman's Avatar
jlbruggeman
Completely normal for that year, just bring a quart along on trips, especially if you like to rev occasionally.
Old Jun 22, 2010 | 10:22 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
must be some bad BP gas causing this leaking oil issue
Old Jun 22, 2010 | 10:45 PM
corvettekid1973
Dang I did just get back from the gulf. Think I should sue BP for a new twin turbo 572c.i. Motor
Old Jun 22, 2010 | 11:51 PM
jrose7004's Avatar
jrose7004
Many 01's had oil problems.
Old Jun 23, 2010 | 12:28 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Funny.
When I first got my 2000 I had the "Low Oil" message twice between the first and second oil changes. Three oil changes later, never happened again. I drive her harder that way back then because I know how. Go Figure.
Old Jun 23, 2010 | 07:27 AM
Jet-Jock's Avatar
Jet-Jock
What Bill said!
Here's a link to the Service Bulletin: Click
Old Jun 23, 2010 | 08:09 AM
The '01 manual tranny cars were known to have a problem with the rings - problem was fixed for the '02 model year. I had this problem with my '00 also - was using a quart of oil every 1200 miles. Dealer replaced the #2 rings under warranty.
Old Jun 23, 2010 | 08:27 AM
WRTHW8's Avatar
WRTHW8
I had a buddy that bought one new and had the same problem. Finally complained enough and GM replaced the engine at 12,xxx miles.
Old Jun 23, 2010 | 03:42 PM
Chevy Guy's Avatar
Chevy Guy
A quart over 4 or 5 months is not an issue. The issue w/ some 01's (Z06's I think) was "ring flutter" in high RPM, low load situations.
In other words, people who drive around at 60mph in second gear to sound cool.
To Losing oil
