AC not blowing though vents
Old Jun 24, 2010 | 03:20 AM
BGC5Vette's Avatar
BGC5Vette
Default AC not blowing though vents
I used my defroster one night last week, the next night I turned it on back to the vents. Never blows though the vents since. I have the duel zone controls.
What could be the problem?
Old Jun 25, 2010 | 12:37 AM
chargedc5's Avatar
chargedc5
Does it blow out your defroster or any one vent??
If so it could be that the vacuum on the ac doors are not working which in a lot of cases results in the plastic tubing under your battery is broken from battery acid.
Old Jun 29, 2010 | 02:54 AM
BGC5Vette's Avatar
BGC5Vette
Blows from defroster on any selection. I notice it blows though the vents when only defroster is on. I have a extended warranty, so it might be the best bet to let them take care of it. Doesn't blow strong from the vents
Old Jun 29, 2010 | 08:58 AM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Vacuum problem!
If its under warranty let them deal with it as it could be corroded vacuum lines or as simple as the 90 degree vacuum line unhooked from the back of the manifold!
Plenty of info on this if you search.
Mario
Old Jun 29, 2010 | 09:10 AM
dougbfresh's Avatar
dougbfresh
Correct, the vacuum hose from the back of the intake, runs behind/under the battery is most likely the culprit. The HVAC system in most GM's default to defrost when INSANE (so you can at least see where your going. Usually a cracked/broken vacuum hose.
Old Jun 29, 2010 | 12:27 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
First go and pull any codes from the DIC, reset the codes for the HVAC this should reset the actuators. You'll hear them after you clear the codes out.
If not then you can follow the Write-Up I did on the Vacuum line fix:
http://forums.corvetteforum.com/c5-g...with-pics.html
Thanks,Matt
Old Jun 29, 2010 | 02:11 PM
Chicago1's Avatar
Chicago1
Thanks,Matt
Great write up!!
Old Jun 29, 2010 | 02:33 PM
madmatt9471
Originally Posted by Chicago1
Great write up!!
Thanks, it had to be done
Thanks,Matt
To AC not blowing though vents
