Gas Door Issue
Old Jun 25, 2010 | 04:43 PM
Logansar's Avatar
Logansar
Default Gas Door Issue
Did a search and found a great thread on how to fix it.
http://forums.corvetteforum.com/c6-c...stay-shut.html
Where can I find a place to look up the part number? Want to check GM Parts Direct but need the part number for the assembly. (Solenoid, cable and spring)
Anyone?
Old Jul 1, 2010 | 02:20 PM
Logansar's Avatar
Logansar
Default Help Gas Door and Head Lights
Needs some advise and confirmation from those who have had these issues.... please post and let me know if I am on the right track.
I posted about my gas door issue and have figure out the problem but now that bothersome head light issue has come up.
I need a little confirmation on what I think is happening....
Gas door - there is no pressure on the plunger so I suspect the spring has gone away. Solenoid functions fine so I need to clean cable and replace the spring. The only way I kept the gas door shut was to hold it shut and push the emergency release in at the same time. Am I on the right track?
Headlight - they pop up but when I close them the right motor runs with a grinding sound of gears slipping. I am guessing that the plastic gear has stripped and needs replacement. Again does this sound correct.. I did notice that when I turn my light switch to the first stop, parking lights, the headlight pop up. I am sure they did not do that till this gear issue started. Has the gear thrown off a micro switch or something.
Old Jul 1, 2010 | 09:08 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Contact Gene or give him a call...http://www.gmpartshouse.com!
Old Jul 2, 2010 | 02:16 AM
Lowcash's Avatar
Lowcash
If you are mechanically inclined you can order replacement gears for your headlight motor from Rodney Dickman.
Old Jul 2, 2010 | 02:40 AM
LoneStarFRC's Avatar
LoneStarFRC
Anyone?
Looks like 10275633
Use either Gene Culley at gmpartshouse OR call Bob (1-800-234-5284)at Fichtner Chev. They will have much better pricing and not screw you on shipping/handling.
HTH
To Gas Door Issue
