[Z06] Clutch Fluid Bladder
Old Jun 26, 2010 | 02:34 PM
ApexerER's Avatar
ApexerER
Default Clutch Fluid Bladder
I am assuming that the bladder in the Clutch Master Cylinder should be bunched up like the one in the brake cylinder. Am I correct? I have been messing with mine for an hour because it is fully extended and I can't get it bunched back up. Am I an idiot or is there a trick to it?
Old Jun 26, 2010 | 03:35 PM
bumble-z's Avatar
bumble-z
Bladder should be fully extended. Looking similar to an udder. Look at your clutch master cylinder closely. You will see the fill mark. Once you have fluid to this mark, insert bladder and install cap.
Old Jun 26, 2010 | 10:56 PM
ApexerER's Avatar
ApexerER
Ok, I guess I am an idiot, that makes it a lot easier......Thank you
To Clutch Fluid Bladder
