From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Originally Posted by FastC6Mike
Hi.
What can I carry in my 2003 vette to be preparded in the event of a flat tire? I have the original tires on my vehicle.
Thank you.
There are plug and patch kits available, as well as small air compressors that plug into the cigarette lighter. If your car is a Z06, a kit like I mentioned was standard equipment as the Z06 didn't have run flats. If you have a coupe or convertible, run flats were OEM, and there are a number of great alternatives available that will offer run flat capability without buying the OEM Goodyear EMT's.
But the best equipment to carry is a cell phone and an autoclub membership.
I had a flat a few months ago and I used a Benz jack (which worked great) and tire wrench I had on board.. I have a compressor on board but doubt it would do much for the tire.. I guess if you were willing to wait it could inflate.
I got lucky, I got a quick ride to a tire shop and the tire shop took me back to the car and let me use their torque wrench to install the tire..
My puncture was a big one and the tire went down in a couple of minutes... Usually they don't go that fast.
I think a small jack and wrench might be handy but the cell and auto club membership might be good too...
I carry a can of sensor safe Fix-A-Flat and a good 12V compressor. Don't bother with those cheap compressors they sell in so called emergency kits. I got mine at Harbor Freight for about $60.00 and it will fill a completely flat tire in about 3 minutes.
I also carry a cell phone and a Premier AAA card. The Premier service will provide a tow up to 200 miles.
I have the Goodyear GS-D3's which are not runflats.
If you have the OEM runflats, you really don't need to carry anything - they are good for up to 200 miles with no air (running at reduced speeds). If you have non-runflats, a good plug kit, small portable air compressor, and a compact jack are good items. Also, emergency road service of some type (either AAA or on your car's insurance) plus a cell phone are recommended.
[QUOTE=Mark C5;1574516694]I carry a can of sensor safe Fix-A-Flat.
Where did you buy the sensor safe Fix-A-Flat? I heard of it buy can't find it.
Also for you guys that carry a plug kit. If you plug a speed tire it can not be repaired correctly by the tire shop w/a patch & plug from the inside. This is what I was told by a local shop.
