yesterday my z overheated, temp went straight to 255 within about 10 min and it got hot right near pep boys, so i bought a new water pump and thermostat. put them both in today and i just op tested it and climbs to 250 at idle in about 15 min. took off the radiator shroud and the radiator is a little dirty but i can feel air flow and it is hot(with coolant). also i turned on my heater and i'm not getting any heat.
i did put a new clutch in about 3 months ago( 5k miles). it is possible that engine hit the firewall on the clutch install.
could a pinched heater pipe cause the overheating?
im lost, i dont know where else to go next.
any thoughts?
Then it sounds like you have an air lock that is preventing the coolant from circulating through the engine. That usually only occurs when coolant has been drained and not refilled properly. It shouldn't have occurred just all of a sudden unless the coolant had been very low. Usually you can clear it by turning the heater on high until the hoses running in and out of the heater get hot.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like you have an air bubble and need to burp the system.
Here's what I found for ya! Try this! Fill the coolingsystem through the surge tank. Fill the coolingsystem with a 50/50 mixture of DEX-COOL® coolant and deionized water. Start the engine. Allow the engine to idle for 1 minute. Install surge tank cap. Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F). Shut off the engine. Remove the surge tank cap. Start the engine. Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank. Install the surge tank cap. Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F). Shut off the engine. Remove the surge tank cap. Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank. Rinse away any excess coolant from the engine and the engine compartment. Inspect the concentration of the engine coolant. Install the surge tank cap.
The solution to my problem was a combination of air in the system, low coolant level, and a dirty radiator. she ran @ 208 deg on the freeway, but started to slowly climbed in city traffic to about 230 deg by the time i got home.
i still think there is a little bit of air in there, i just read in another thread to pull the small hose under the throttle body. I'll try that tomorrow.
You said dirty radiator, are you referring to the area you see when you lay down and look at the intake area under the nose?
If so that is the condenser not the radiator. You need to either remove the top cover for the radiator/condenser or pull up on some ramps and slide underneath and look between the radiator and condenser. That small space sucks up tons of debris. Getting it cleaned out is another challenge.
The purge procedure described by Bill should be sufficient.
At 81k, I'd start considering the radiator is plugged up and air is not flowing through it. Over time water and dirt gets in between the fins and plugs them up as a solid reducing air flow. Those fins are super delicate. You would need to either remove it and soak and clean it or just replace the radiator with a new one. Some people will tell you to get an all aluminum but the stock one will work fine especially brand new.
