Wipers stop workin! Need help
Old Jun 30, 2010 | 09:09 PM
Waynedrake's Avatar
Waynedrake
Default Wipers stop workin! Need help
Someone tell me what and how to fix my problem.
Sure will be happy if u help me out here.
Old Jun 30, 2010 | 09:18 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
You drive it in the rain?
Old Jun 30, 2010 | 09:40 PM
Bill Vett's Avatar
Bill Vett
Did you just wash the car or did it sit in the rain???? Need more info ....
Old Jul 1, 2010 | 11:53 AM
Waynedrake's Avatar
Waynedrake
I was drivin in the rain then they just stop. Check the fuse and it was good
need to know is it the motor or the switch.
Old Jul 1, 2010 | 12:18 PM
Bill Vett's Avatar
Bill Vett
The first thing I would do is check the udders to make sure they're clean and drain properly. Allow the motor to dry out and give it a try. If you need help locating the udders check this thread in the tech stickys.....http://forums.corvetteforum.com/c5-t...ak-checks.html
Old Jul 1, 2010 | 12:47 PM
hotwheels57's Avatar
hotwheels57
You might be able to help yourself if you're willing to do some research. Every technical question that's ever been asked/answered can be found in the forum archives. The trick is in the keywords used. Your situation should be simple to find lots of past discussions.
In C5 Tech (it's a technical issue), use search or search this forum (in the red banner).
Use keywords "windshield wiper quit" or similar words. You should find many past threads/replies and some with images of the udders, with suggestions on how to deal with the issue.
Here's your other thread from this morning...
http://forums.corvetteforum.com/c5-t...d-ur-help.html
Old Jul 1, 2010 | 01:09 PM
2vettes2go's Avatar
2vettes2go
Just to be on the safe side, replace the wiper fuse. sometime it is hard to tell a blown fuse.
Old Jul 1, 2010 | 02:45 PM
mikelmco's Avatar
mikelmco
Old Jul 1, 2010 | 04:30 PM
MStrahan's Avatar
MStrahan
I recently bought an 04Z and the wiper motor was weak. The seller had a new motor, but since I drove from out of town to get the car the offer was made to let me put it in or I could help..read go get the beer. It's a fairly easy job. The morning I was going to take her home it was raining and I turned the wipers on and one swish then STUCK. Went back to the seller's house tore into it again. We wanted to make sure there were no connections loose. He offered to take the cost of a new motor off the selling price, but I wanted to take a look at things before it cost him a few hundred dollars. Long story short...there was a torx head bolt on the top of the wiper motor that was loose. Tightened her up and POOF wipers back to working.
Try the simple first, fuses and what I found.
Best of luck.
To Wipers stop workin! Need help
