How to replace gauge faces
Old Jul 2, 2010 | 06:59 PM
stormrider's Avatar
stormrider
Default How to replace gauge faces
Hello everyone. I have had a set of SpeedHut gauge faces sitting in my closet for over a year and now I am ready to install them. I found threads on how to remove the gauges but I can't get the SpeedHut face plates to slide over the gauge needles. Can anyone point me in the right direction?
Thanks!
Mark
Old Jul 2, 2010 | 07:37 PM
swpowell's Avatar
swpowell
Mark, Thanks for asking the question. I was just about to ask the same thing. Now I can just follow this thread.
Old Jul 2, 2010 | 08:26 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I have the aluminum gauge rings and was thinking about replacing the faces as well. I'm also following this thread!
Old Jul 2, 2010 | 10:23 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Old Jul 2, 2010 | 10:42 PM
Zorlac's Avatar
Zorlac
I was sent here when I did some audio work on my C5. This should help you out.
http://www.vetteessentials.com/instr...zel_howto.html
Old Jul 3, 2010 | 12:12 PM
stormrider's Avatar
stormrider
Thanks for the link but I am looking for help with the next step, installing the new face plates and getting them behind the gauge needles.
Old Jul 3, 2010 | 12:22 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Corvette Fever has a step by step guage upgrade w/pics. Here's the link and hope it helps you out. Good luck.
http://www.corvettefever.com/howto/19298/index.html
Old Jul 3, 2010 | 12:58 PM
stormrider's Avatar
stormrider
Great link! Unfortunately the faceplates I have are ridged so I can't bend them around the needles. The link states not to remove the needles so now I am really at a loss as what to do.
Old Jul 3, 2010 | 04:03 PM
kh400's Avatar
kh400
I bought the face plates they have on ebay that light up aqua at night. Also bought a damaged cluster to experiment with. These plates are flexible enough so you can get them over the needles.I used some clear RTV to glue them in place . All went well till I got some glue in the hole the tach needle goes in and screwed up the tach. But boy do the guages look good when lit up!! So I guess it can be done with a little patience. Good luck!!!!
Old Jul 3, 2010 | 10:48 PM
SugarDemon's Avatar
SugarDemon
2015 C5 of Year Finalist
I put a flexible face plate on my 01 Chevy Z71 truck about six years ago. My instructions said to take the needles off but gave me a couple of tips. I drew a diagram of where the needles were pointing when my car was warmed up and idling. (ex: 600 rpm, 190 degrees temp, 3/4 tank gas, etc) Then I drew another diagram of the needles when the truck was totally cold. Pulled the needles, replaced the face plate and put the needles back on in their exact positions. Warmed the car back up to steady state and measured to see if I got the same readings as before. I did. Had a friend test my speedo by driving beside me at a couple of different speeds. Everything checked out.
There was no way I was ever going to get my face plate over those needles.
To How to replace gauge faces
