Towing
Old Jul 3, 2010 | 11:35 AM
ianj650's Avatar
ianj650
Default Towing
I'm relocating and want to tow my C-5 (manual transmission) behind another vehicle. This is a typical tow dolly where the front wheels are secured, on the dolly, and the rear wheels are on the road way. Is this an acceptable method? Should I have any concerns in towing the vehicle this way? Thank You
Old Jul 3, 2010 | 12:00 PM
mikelmco's Avatar
mikelmco
I would put it on a trailer. I plan on doing this when I move next month.
Mike
Old Jul 3, 2010 | 01:00 PM
jcgunn's Avatar
jcgunn
Use a flatbed car trailer. The car dolly requires you to remove the driveshaft on a rear wheel drive vehicle (many don't and just let the transmission spin in neutral...not good)
Old Jul 3, 2010 | 01:20 PM
m6 c5's Avatar
m6 c5
if im not mistaken gm says specifically to not tow the corvette
Old Jul 3, 2010 | 02:39 PM
ronssito's Avatar
ronssito
Old Jul 3, 2010 | 02:59 PM
hotstang_46's Avatar
hotstang_46
no tow dolly.....worst case is you can rent a flat bed from uhaul
Old Jul 3, 2010 | 03:08 PM
olbear1962's Avatar
olbear1962
Old Jul 3, 2010 | 03:30 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
From the 2003 owners manual:
Your vehicle was not designed to be towed with any of its wheels on the ground. If your vehicle must be towed, see “Towing Your Vehicle“ earlier in this section.
The “Towing Your Vehicle“ section says "call a professional"
To Towing
