Lubricate Power Antenna?
Old Jul 3, 2010 | 02:25 PM
daved1945's Avatar
daved1945
Default Lubricate Power Antenna?
Is it recommended to lubricate the mast on the power antenna? If so, what lubricant should be used?
Old Jul 3, 2010 | 03:18 PM
vafirevet's Avatar
vafirevet
Default No
I believe I read in the owner's manual that it doesn't get anything but wiped off to clean it. Nothing else is added...
Look in the book?
Old Jul 3, 2010 | 08:04 PM
rochesterdriver's Avatar
rochesterdriver
Dave,
The manufacturers of the antenna masts like it if you wax the shafts.
Nothing down in the antenna, just the shafts.
Polish him nicely, he'll thank you.
Jim
Old Jul 3, 2010 | 10:00 PM
dobewillie's Avatar
dobewillie
Ashot of wd40 on a rag and wipe cant hurt
Old Jul 3, 2010 | 10:22 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Lemon Pledge
Old Jul 3, 2010 | 10:36 PM
Bill Vett's Avatar
Bill Vett
Originally Posted by ztheusa
Lemon Pledge
spray on a rag first then wipe dry. Oil is not good , it picks up dust and dirt and makes the antenna stick.
Old Jul 3, 2010 | 11:51 PM
minitech's Avatar
minitech
Yes, NEVER oil an automatic antenna. It will lead to collection of debris and jamming / failure of the antenna. Just keep it clean.
Old Jul 4, 2010 | 04:14 PM
bighank's Avatar
bighank
Default Believe GM manual says mineral spirits
Thought I saw that in either the owners or shop manual. Antennamastsrus says don't lubricate it.
Old Jul 4, 2010 | 06:41 PM
Here's what my owner's manual states on power antenna care:
1. Turn on the ignition and radio to raise the antenna.
2. Dampen a clean cloth with mineral spirits or equivalent solvent.
3. Wipe the cloth over the mast sections, removing any dirt.
4. Wipe dry with a clean cloth.
5. Make the antenna go up and down by turning the radio or ignition off and on.
6. Repeat if necessary.
Notice: Don't lubricate the power antenna. Lubrication could damage it.
To Lubricate Power Antenna?
