One more thing I need to fix on my 00 vert. My climate control blows hot air from the drivers side and cold air from the passenger side when I put on the air conditioning. Found a guy who refurbishes them but he say his fix will not correct this problem.
I am currently working on my 1998 right now. With the enging running, and A/C running I pulled out the #27 fuse in the passenger side floor board, in an attempt to re calibrate the actuators. I too have hot on the drivers side and cold on passenger side. It worked for about 3 minutes and went back to hot. I am stumped but still reading forums!
Sorry, dont have the link but you will find it here with enough searching. You can recalibrate the actuator by pulling a fuse or disconnecting the battery or something like that. It may fix the problem and is worth researching before pulling the whole thing apart or replacing parts.
