Anyone having this problem with window valet?
Old Jul 6, 2010 | 06:56 PM
Guilty in Chicago's Avatar
Guilty in Chicago
Default Anyone having this problem with window valet?
mine is possessed....when activating the key fob the windows go down/up with radio on/off as its supposed to, no problem. But the radio which is supposed to always stay on after the ignition is turned off does so intermittently, whenever it feels like it. Anyone else have this problem, or a solution to it? Thanks.....
Old Jul 6, 2010 | 08:55 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I had that problem a long time ago, all I did was reprogram everything...just start from scratch like you did wheh you first got it. I have a TV remote that did the same thing...it's all about the 'progress' of the digital age...
Old Jul 6, 2010 | 09:03 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
As I recall there is also an option in the valet for the radio. I imagine that when locking the doors normally (one press of the FOB) it will work off the vehicle settings, and press the FOB 3 times to roll up windows it will work of the valet settings (which may be set to off). So as said before go through the settings and reprogram the aux power setting to make sure it's set the way you want it.
One more thing to try is unplugging it and plugging it back in, mine acted up before and that worked
Old Jul 6, 2010 | 11:16 PM
Baron138's Avatar
Baron138
My Valet doesnt work with the after market alarm in the car. It wont work with out the G.M. fob and I'm not going to carry 2.
Old Jul 7, 2010 | 06:32 PM
Guilty in Chicago
thanks gentlemen.....I'd planned on doing just that and am glad to hear that the problem went away.....
To Anyone having this problem with window valet?
