problem getting door module fixed-any help?
Old Jul 6, 2010 | 07:36 PM
squigly's Avatar
squigly
Default problem getting door module fixed-any help?
I just took out the HVAC and got the resistors soldered and it works perfect. Also took out the door module because the power window won't work and I have a convertible-2000-so kind of need it working. I can't find anywhere to fix it because they say that the board is covered with a plastic coating and is too difficult to do. I don't know for sure if it is the relay. Can hear a click from the module when pressing up or down on pwr window switch. Tried slamming door, banging, felt motor and cylindrical metal piece past the motor became very hot-worried it was going to burn so removed fuses from kick panel. Hope someone can help me out with diagnosis or difficulty of getting the relay soldered. Thanks
