[Z06] passenger window problem
Old Jul 8, 2010 | 01:39 PM
yangee's Avatar
yangee
Default passenger window problem
I have a prolem with my passenger window. It dosen't work, when I push the down or up botton nothing happen.....My other window work fine. Is it a fuse?
thanks
Old Jul 8, 2010 | 03:28 PM
BaileyD's Avatar
BaileyD
I had the same problem with mine, can you hear the relay clicking?
I fixed mine by removing the interior door panel and tapping the end of the window motor with a screwdriver while pushing the down button, has never failed since
Old Jul 10, 2010 | 08:56 AM
machz800ps's Avatar
machz800ps
Hey red devil thanks, I almost went and bought a new motor yesterday saw this post and tore my pass. door down hit the end with a screwdriver (took a few times) and pushed down on the window and the darn thing works!!!!! the first time it worked, it stopped and then i hit the motor again and pulled up on the window and has not stopped working cycled about 20 times( not at one time)
Steve
Old Jul 10, 2010 | 09:52 AM
BaileyD's Avatar
BaileyD
Steve
Glad you got it working, mine was sluggish the first few times but it soon ran smooth like the drivers side.
Denis
Old Jul 25, 2010 | 08:23 PM
yangee's Avatar
yangee
I don't hear the relay clicking.....where did you tapp exacly, is it where a put a mark on the picture...
Old Jul 25, 2010 | 08:30 PM
BlackCloudPSD's Avatar
BlackCloudPSD
5th Gear
for what its worth, 95% of the time it will be the motor not the switch on an f-body.
Old Jul 25, 2010 | 08:59 PM
wildwall's Avatar
wildwall
there is a circuit board inside that box you were tapping on. There are relays on the circuit board for the window and doors locks. These relays crap out. It happened to me. The good news is you can replace the relays very cheaply. Check this out:
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Jul 26, 2010 | 07:52 AM
yangee's Avatar
yangee
thanks for the link...that's what I need..
Old Jul 27, 2010 | 02:23 PM
BaileyD's Avatar
BaileyD
I tapped the back of the window motor, you have to put your hand inside the door panel.
Old Jul 27, 2010 | 11:37 PM
BobbyC3's Avatar
BobbyC3
From: Common courtesy and common sense are not common.
St. Jude Donor '09-'10-'11-'12-'13
Bill Curlee usually has the answer...........
http://forums.corvetteforum.com/c5-t...tion-long.html
Old Aug 10, 2010 | 02:17 PM
yangee's Avatar
yangee
thanks Bobby with that link it's work and I resolved some other problems...
To passenger window problem
