Any ideas - Gentex Mirror Compass Display
Old Jul 9, 2010 | 12:06 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Default Any ideas - Gentex Mirror Compass Display
I have the Gentex auto dimming mirror with the Compass display w/Donnelly wiring harness. Display just quit working. Map lights come on fine. Just the display. I checked the wiring in the footwell and the orange wire connection is fine.
Any ideas?
Old Jul 9, 2010 | 12:57 PM
TP C5's Avatar
TP C5
Any ideas?
Check your temp control probe underneath the car. Maybe something is pinching the wire? I have the same set up but no problems.
Old Jul 9, 2010 | 01:38 PM
c5BlackBeauty
Lifetime Member
Okay. I'll give that a whirl. Thanks
Old Jul 9, 2010 | 05:38 PM
jdmvette's Avatar
jdmvette
Night Owl for life
check that the display button on the mirror isnt turned off.
Old Jul 9, 2010 | 06:03 PM
c5BlackBeauty
Lifetime Member
Ha.....now wouldn't that be a hoot. I didn't even know it has an off/on. I'll head out to the garage when I get back and check. Thanks for the tip.
Old Jul 9, 2010 | 06:25 PM
j84buick's Avatar
j84buick
Why would the temp probe wire cause the compass to stop working? Do you also have the temp on the mirror like my Gentex mirror does? Even when the temp wire is not hooked up it should still show 0 or something if memory serves.
The only idea would be to connect the mirror up to the battery. That will eliminate everything in between. If there is still no display then it's time for a e-bay search.
Old Jul 10, 2010 | 08:23 AM
clif's Avatar
clif
St. Jude Donor '09-'10
If the temperature probe is not connected, the lower hafl of the display shows 'OC' for Open Connection. Mine is doing that now. I need to figure out why.
To Any ideas - Gentex Mirror Compass Display
