Question on coil overs.
Old Jul 11, 2010 | 03:16 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Default Question on coil overs.
I am thinking of installing coil overs, My question is how hard is it to remove the Z51 springs?
My C5 is telling me he wants coil overs...lol
But not sure if I want to go through the spring removeal.
Old Jul 11, 2010 | 05:20 PM
8VETTE7's Avatar
8VETTE7
A couple months back I swapped the factory base level springs in my 2004 for some 2003 Z06 leafs. The rear leaf R&R was very easy. The front was a bit of a challange with significantly more disassembly but not all that bad. I did have the luxery of an air conditioned garage with a lift (only wish it were mine). I probably would not have tried it if all I had were jack stands.
Here is a link to the thread I used to guide me through the process:
http://www.ls1howto.com/index.php?article=20
Let us know how it goes.
Old Jul 11, 2010 | 05:25 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I just installed Coilovers on jackstands and it was pretty easy actually... I used Toque's instructions;
http://mysite.verizon.net/res0aae8/coilover.html
I didn't remove the coolant or washer fluid tanks though, other then that the instructions were excellent...
To Question on coil overs.
