Climate control
Old Jul 13, 2010 | 10:39 PM
dustysZ's Avatar
dustysZ
Default Climate control
The digital display on my control panel went out. Is there a simple fix or is it another trip to GM?
Old Jul 14, 2010 | 03:17 AM
Jistari's Avatar
Jistari
Pretty common problem. You can fix this yourself if you dont mind soldering a few components (not hard to do) see link.
http://forums.corvetteforum.com/c5-g...ery-dim-2.html
Or you might be able to send it out to be fixed (although I dont recall who still does them).
Or you could replace the unit, last time I looked it wa s about $300.
I soldered mine, works like a charm.
Old Jul 14, 2010 | 05:44 AM
Or if you don't want to mess with it, you can send it to a place like JW Motoring - they repair the dim display and can install LEDs in it also.
Old Jul 14, 2010 | 07:43 AM
dustysZ's Avatar
dustysZ
Will try soldering it. Found another post explaining how to do it. Should have looked befor asking.
Thanx
To Climate control
