Smells Like Oil
Old Jul 14, 2010 | 02:44 PM
UM Rebel's Avatar
UM Rebel
Default Smells Like Oil
My 2004 has started smelling like oil. There are no signs of leaks or burning oil and level is full. Cap is tight and Oring is intact. I thought maybe PCV valve, but found out it doesn't have one. Does anybody have ideas of where it could be coming from?
Old Jul 14, 2010 | 02:45 PM
had2have-it's Avatar
had2have-it
How close to the Gulf of Mexico are you?
Old Jul 14, 2010 | 03:10 PM
UM Rebel's Avatar
UM Rebel
Heh, that occurred to me too. I live in South Louisiana. But it's definately coming from the car.
Old Jul 14, 2010 | 03:13 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Check for leaking rear axle seals.
Sounds like you are going to need to take a crawl "down under" to find out what is going on.
Old Jul 14, 2010 | 03:20 PM
2003 electronblue's Avatar
2003 electronblue
Check your differncial they always smell when they leak...leaky butt...
had2have-it
I'm in the west end of Metairie near the lake. Somedays with certain wind currents you can notice a strong odor. Good luck with the car.
Old Jul 14, 2010 | 03:22 PM
UM Rebel's Avatar
UM Rebel
Went under yesterday. Didn't see or feel anything, but was mostly looking under engine. I'll go check rear now.
Old Jul 14, 2010 | 03:38 PM
1989vette's Avatar
1989vette
I have the exact same problem, but with two totally different motors. Does the car use any oil between changes? I have an 01 camaro with a V6 that uses half a quart between oil changes, and an 01 3500 496 truck that uses over a whole quart. Both have low quality valve seals that cause oil to be sucked down the valve guide and burned off in the exhaust. It explains both the usage of oil and also the smell. Does it get worse when you decelerate? I know it may not be your problem, just something to think about if you find no visible signs.
Old Jul 14, 2010 | 03:54 PM
craig-o's Avatar
craig-o
I had the same thing a few years ago - mine had that distinct odor I associate with gear oil, not engine oil; but it definitely seemed to be coming from the engine compartment and not the transmission or differential. I never did track down the source, and nothing was leaking.
It did finally stop when I had some work done on it, but it may have been coincidental. I had the passenger-side A.I.R check-valve replaced (code p1416). To do that the intake manifold had to be removed, and as long as it was off, I asked them to replace the oil pressure sensor. That was 3 years ago, and the odor has never returned. Might you have an active p1416 code? It's a long shot, but thought I'd share my experience.
Old Jul 14, 2010 | 05:26 PM
UM Rebel's Avatar
UM Rebel
Checked under rear. No sign leak anywhere. All diagnostic codes are LDCM and RDCM and all are history. Car does not use any oil between changes. Last oil change was about a month and half. One thing there ... I let the oil change dude talk me into Royal Purple. I never have used anything except Mobile 1 til then. Could that be it?
Old Jul 14, 2010 | 05:31 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Wouldn't be the brand, but if they spilled some in the engine compartment or on the exhaust manifolds that could be the problem. Worth a look anyway....
Good luck
Nick
Old Jul 14, 2010 | 05:32 PM
vafirevet's Avatar
vafirevet
No leaks...Maybe he spilled a little bit of oil on the motor while filling it back up and that is what you are smelling? A little drip from a can will get in places that gets really hot...
Old Jul 14, 2010 | 05:57 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Well, at least you have the peace-of-mind now that nothing is seriously leaking!
Old Jul 15, 2010 | 08:47 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have noticed that after "spirited" driving the smell of the tires can smell similar to burned oil. Could that be what you are smelling?
Old Jul 15, 2010 | 08:48 AM
jrose7004's Avatar
jrose7004
Did you recently do an oil change?
Old Jul 15, 2010 | 12:39 PM
UM Rebel's Avatar
UM Rebel
It's been over a month since oil change. And, heh, heh, I know the burning tire smell from "spirited" driving.
I pressure washed underhood and underneath yesterday afternoon. Hopefully that will get it.
Old Jul 17, 2010 | 05:17 PM
UM Rebel's Avatar
UM Rebel
I found it! There's a hose that runs from engine valley to manifold. Only about 4 in long. It's part of the PCV system, but the 2004 does not have a PCV valve. It makes a very sharp bend to make the connection. There was a split in the bend that was letting just a drop of oil get on the hot engine. The hose was marked GM 11/32 but I couldn't make an 11/32 hose slip over the fittings. Wound up using 3/8 PVC hose. Also, I could not make a hose as short as original go on without a kink in it. Made replacement longer with a gradual loop. Thanks for everyone's advice!
To Smells Like Oil
Old Jul 18, 2010 | 03:27 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Wow....good job! And thanks for letting us know. I dislike it when people ask for help and everyone chips in but we never hear from them again.
Old Jul 18, 2010 | 03:58 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Glad you found the problem and fixed it...
If your 2004 Vette has no PCV valve then what is this for?
Description:PCV Year:2004 MSRP:$4.58 Your Price:$3.39
GM>>>PCV valve, Corvette
2004 retail$4.58 our price$2.71
I have a 2004 Corvette also and I thought it had a PCV valve...
Old Jul 21, 2010 | 04:36 PM
UM Rebel's Avatar
UM Rebel
@ Yello95 I don't know what to say except mine is not like your diagram. Here's a pic
