Wheel Spacers
Jul 14, 2010 | 08:22 PM
Wheel Spacers
I just purchased 19 x 1O " back rims
from reading it seems the 68mm offset wil require a spacer
who has a source for longer wheel studs ..??
Jul 14, 2010 | 09:03 PM
St. Jude Donor '17
Quote:
Originally Posted by
Hi/Tek/Vette
It would be better to get the 1" wheel adapter instead of spacers with longer studs.
It is the safer approach to avoid sheering off lug bolts.
I would suggest a test fit before doing either. I doubt you need either.
if you had 18s 65 offset stock
your new rims will be
16mm LESS (the inside of the wheel to the strut housing)
EXTEND an extra 10mm (position of the outside edge of the wheel)
Jul 14, 2010 | 10:53 PM
Hi/Tek/Vette
those offsets won't require longer studs or spacers.
the 19x10 +79mm wheels are the ones that needed to be spaced out.
