Plug This?
Old Jul 15, 2010 | 01:17 PM
Wallly's Avatar
Wallly
Default Plug This?
I did order new tires today (non-RF finally), but was wondering if you think I could plug this and drive it for a week until my new tires get here? It's a screwdriver bit from when I installed some new lights over my garage
Old Jul 15, 2010 | 01:18 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Big hole pretty close to the sidewall.......
Personally - I wouldn't want to drive on that.
Old Jul 15, 2010 | 01:42 PM
Wallly's Avatar
Wallly
I was afraid you would say that! I'm just pissed that Im gonna miss a week of summer driving. We don't get many of those around here
I thought it would be impossible to get a screwdriver bit in a tire, but then my dad told me about how he ran over a HOUSE KEY and it punctured his tire.
Old Jul 15, 2010 | 01:48 PM
srs244's Avatar
srs244
St. Jude Donor '09 thru '26
Originally Posted by Wallly
...but then my dad told me about how he ran over a HOUSE KEY and it punctured his tire.
pretty much anything even remotely pointed when introduced at the right angle of attack will puncture a tire, unfortunately. good reason to be hospital like when finishing a job and accounting for all the tools used, lol! (i know, loads easier said than done).
if you pull the tire off and have it correctly patched (vulcanized, etc) from the inside, you might have a chance of a good repair. i agree however, i wouldn't trust a plug on something that large located where it is located.
Old Jul 15, 2010 | 01:49 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Actually, that hole may not be as large as you think. Looks like the largest part of the bit is just sticking into the rubber, while only the short, smaller part of the bit penetrated the wall. It isn't so close to the sidewall that I would be all that concerned, so long as you don't plan on hitting the curves hard.
I'd pull it out, and plug it. Go about plugging it normally, don't try to double up plugs or anything. If it holds air, you're good to go. It isn't like you'll be driving on it forever.
Old Jul 15, 2010 | 01:51 PM
had2have-it's Avatar
had2have-it
Plug it, see what happens (while avoiding long trips/high speeds) and let us know what happens.
Old Jul 15, 2010 | 01:53 PM
blacksedan87
Want to get really pissed? I just bought brand new Continental's for my black car.....maybe less than 300 miles on them. I ran over what looked like a Chrysler ignition key, and the tire went flat within about 10 minutes. I had our wheel/tire place that specializes in high end wheels break down the tire, and do a hot patch and plug. The tire is fine and they said that the speed rating won't be affected - but a brand new tire?
Old Jul 15, 2010 | 01:54 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
No way, too close to the edge. There is an excellent write up on one of the tire retailers websites that goes into a detailed explanation of plugging/patching run-flats and high speed rated tires.
Old Jul 15, 2010 | 02:07 PM
sneakelman's Avatar
sneakelman
Now THAT sucks!
Old Jul 15, 2010 | 03:03 PM
corvettedaddy11's Avatar
corvettedaddy11
Sniper had you in his cross hairs,you probably have to purchase a new tire !!! damn that sux!!
Or try fixing it it couldnt hurt!!
Old Jul 15, 2010 | 03:09 PM
Wallly's Avatar
Wallly
Yea, that's much worse than my story, at least my tires were nearing the end of their life!
Old Jul 15, 2010 | 04:39 PM
Take the tire down to a very good tire repair store and see if they will even touch it with the puncture that close to the edge. They might, and if they repair it, just take it very easy until your new tires arrive.
Old Jul 15, 2010 | 05:07 PM
Sinister-one's Avatar
Sinister-one
Put a plug in it, you'll be okay for the week.
Old Jul 15, 2010 | 06:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
One way to find out PLUG it and find out if it holds air good and if it does just don't go crazy driving it - just enjoy the fact that you still can drive and when the new treads come in let the hammer fly
Thanks,Matt
Old Jul 15, 2010 | 06:12 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I'm in with the majority.....to close to the side. I wouldn't chance it.
Old Jul 15, 2010 | 07:11 PM
itzza427's Avatar
itzza427
I'd give it a shot with a good plug kit,,,,as long as it is going to be only easy cruising and around town stuff. I WOULD NOT trust it for a trip or extended highway use!! Depends on how you are going to use it!! I agree it looks like the point would just barely be puncturing the inner seal of the carcass!! My opinion IS based on the assumption that it is a run-flat tire!!
Old Jul 15, 2010 | 07:16 PM
jrose7004's Avatar
jrose7004
I don't think that a tire shop would plug that tire from a liability standpoint!
To Plug This?
Old Jul 16, 2010 | 03:20 AM
atlas094's Avatar
atlas094
It is close, but does not look to be into the flex of the sidewall. Try a plug and confirm if it holds air - is so you are ok for a week until your new tire is installed.
Old Jul 16, 2010 | 03:45 AM
Choreo's Avatar
Choreo
Looks like these may be Michelins?
If it were me I would take it to some place like Discount Tire and if they will patch it from the inside, you will probably be safe as long as you don't push it too hard. I have had at least 8 patches on various RFs sometimes as many as 2 per tire on GYRFs (Michelin only allows on patch per tire before replacement). Some have been that close to the sidewall and I never had a problem with any of them, but I never used a "plug".
Old Jul 16, 2010 | 04:14 AM
SCM_Crash's Avatar
SCM_Crash
Time for a new tire. Don't plug anything that close to the side wall. They have a chart at most tire shops that shows where you can plug. The margin between the sidewall and the center of the tire is usually 1/2 inch. That's way in the red there.
