options on my C5
Thanks in advance
RPO G92: Axle, Rear, Performance Ratio 3:15
Go here for all the information you need: http://corvetteactioncenter.com/specs/c5/
Enjoy your Vette
Nick
1999 Corvette RPO Codes
AAB Memory, Driver Convenience Package
AG1 Power Seat Adjuster, Driver, 6-Way
AG2 Power Seat Adjuster, Passenger, 6-Way
AK5 Inflatable Restraint System, Front Seat, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Reclining Seat, Driver and Passenger (Sport Seat)
AR9 Reclining Seat, Driver and Passenger, European Style (Base Seat)
AX4 Conversion, Seat Belt, European
BAG Loose Parts Bag, Export
B34 Covering Front Floor Mats, Carpeted Insert
B4H Modification, Noise Control, Export
B84 Molding, Body Side, Exterior
CC3 Roof Panel, Removable (Transparent)
CF7 Roof Panel, Removable (Non-Transparent)
CJ2 HVAC System, Air Conditioning, Automatic Temperature Control (Dual Zone)
CU7 Country Code, Kuwait
CU8 Country Code, Saudi Arabia
CV5 Country Code, Japan
CW2 Country Code, Gulf States
C05 Roof, Convertible Folding
C2L Roof Package, Dual Removable (consists of CC3 and CF7)
C60 HVAC System, Air Conditioning, Manual Control
DL8 Mirrors, Outside, LH/RH Remote Control Electric, Heated
D42 Shade, Rear Compartment Security (includes cargo net)
EXP Export, I.P.C.
E45 Cover, Convertible Top, Protective
FE1 Suspension System, Soft Ride
FE3 Suspension System, Sport
FE9 Certification, Federal Emission
F45 Chassis, Selective Real Time Damping
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
IL3 Trim, Interior Design (L3) (Base w/ AQ9)
IP3 Trim, Interior Design (P3), Leather (Base w/ AR9)
JL4 Control, Active Brake
JL9 Brake System, Power, Front & Rear Disc, Antilock, 4-Wheel
K05 Heater, Coolant
K29 Module, Powertrain Control (Non-OBD II, Unleaded)
K63 Generator, 110 Amp
LS1 Engine, Gas, 8-Cylinder, 5.7L, MFI, Aluminum (VIN G)
MAE Marketing Area, Europe
MM6 Transmission, Manual 6-Speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-Speed Provisions
MX0 Merchandised Transmission, Automatic O/D Provisions
M30 Transmission, Automatic 4-Speed, 4L60-E, Electronic
NA3 Emission System, Japan
NA7 Emission System, European
NB6 Emission System, California, Tier 1
NF2 Emission System, Federal, Tier 1
NK4 Steering Wheel, Sport Leather
NM2 Emission System, Export, Leaded Fuel
NP7 Steering Column, EEC Approved
NV7 Steering, Power, Variable Effort
N37 Steering Column, Tilt, Telescoping
N73 Wheel, Custom Sport Magnesium
QD4 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, Styled
QF3 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, w/Special Offset
TR9 Lamp Group
T62 Lighting, Daytime Running -- Delete
T82 Headlamp Control, Automatic On-Off
T84 Headlamps, RH Rule of Road, E Mark
T85 Headlamps, LH Rule of Road, E Mark
T89 Lamps, Tail, Stop & Turn, Export
T90 Lamps, Signaling & Marker, Front
T93 Lamps, Tail, Stop & Turn, Special
T96 Lamps, Fog
UD4 Alarm, Vehicle Speed, 120 km/h
UK1 Radio Frequencies, Japanese
UL0 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UL2 Radio Frequencies, European
UN0 Radio, AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UQ5 Speaker System, 4, Dual Front Door Mounted, Dual Extended Range Quarter Mounted
UV6 Display, Head Up
UV7 Antenna, Windshield, Rear Lift Window, Radio
UZ6 Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted
U1S Changer, Remote Compact Disc
U19 Instrument Cluster, Metric (Canadian, Export)
U52 Instrument Cluster, Electronic
U73 Antenna, Fixed, Radio
U75 Antenna, Power, Radio
VB1 Label, Shipping, Japan
VC5 Label, Shipping, Except US/Japan
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VG1 Protector, Transit Coating, Underhood
VG9 Protector, Transit Coating, Exterior Body
VH5 Plate, Vehicle Identification
VL4 License Plate Mounting Package, Front, EEC
V49 License Plate Frame (front)
V73 Vehicle Statement, US/Canada
V76 Tow Hooks
V78 Vehicle Statement Delete
V87 Vehicle Statement, Gulf States Organization
XGG Tire, Front, P245/45R17-89Y, BW TL SBR HW4, EMT
XMC Tire, Front, P245/45R17-89Y, BW R/PE ST TL HW4
YGH Tire, Rear, P275/40R18-94Y, BW TL HW4 SBR, EMT
YME Tire, Rear, P275/40R18-94Y, BW TL HW4 SBR
Z19 Performance Package, Coupe
Z49 Modifications, Canadian, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z51 Performance Package, Handling
10U Primary Color, Exterior, Arctic White
11U Primary Color, Exterior, Lt. Pewter Metallic
13U Primary Color, Exterior, Sebring Silver Metallic
16T Top Color, Convertible, Bright White
19I Interior Trim, Black
193 Trim Combination, Leather, Black
23U Primary Color, Exterior, Nassau Blue Metallic
28U Primary Color, Exterior, Navy Blue Metallic
41T Top Color, Convertible, Black
41U Primary Color, Exterior, Black
67I Interior Trim, Lt Oak
67T Top Color, Convertible, Lt Oak
673 Trim Combination, Leather, Lt Oak
70U Primary Color, Exterior, Torch Red
86U Primary Color, Exterior, Magnetic Red Metallic
92I Interior Trim, Lt Gray
923 Trim Combination, Leather, Lt Gray
94I Interior Trim, Firethorn Red
943 Trim Combination, Leather, Firethorn Red
Does the Z51 handling package come with drilled and slotted rotors? if so even though my original window sticker has it as a option they are not drilled or slotted rotors, but does have the 3.15 performance axle ratio that has to be ordered with the Z51 for the automatic. I went by the RPM sheet someone posted so I know I have the 3.15 rear gears. Also how can I tell if the shocks and sway bar are the Z51 option?
VEHICLE INFORMATION
Merchandising Model : 1YY07 Warranty Start Date : 10/17/1998
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PETE MOORE CHEVROLET, INC.
PO BOX 18848
PENSACOLA , FL 32523-8848
(850) 456-7000
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/27/2002 260598 # J4100 - GENERATOR REPLACEMENT 36898 miles
02/27/2002 260598 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 36898 miles
11/16/2001 250114 # C1421 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - LEFT - REPLACE 33960 miles
11/16/2001 250114 # C0101 - GLASS, FRONT DOOR - LEFT - ALIGN 33960 miles
11/16/2001 250114 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 33960 miles
10/22/2001 247171 # E7620 - STEERING SHAFT LOWER BEARING REPLACEMENT 33000 miles
10/22/2001 247171 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 33000 miles
10/16/2001 246570 # B2530 - LATCH ASSEMBLY AND REAR BRACKET, ROOF PANEL STORAGE - REPL 32511 miles
10/16/2001 246570 # R4490 - REMOTE CONTROL DOOR LOCK TRANSMITTER REPLACEMENT 32511 miles
10/16/2001 246570 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 32511 miles
09/24/2001 066774 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 32176 miles
09/24/2001 066774 # V0743 - ECL RELAY HARNESS REPLACE 32176 miles
09/24/2001 066774 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 32176 miles
09/24/2001 066774 # J0660 - BELT, SECONDARY ACCESSORY DRIVE - REPLACE 32176 miles
08/15/2001 064924 # Z7901 - 1-DAY COURTESY TRANSPORTATION 30013 miles
05/29/2001 061360 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 30013 miles
05/29/2001 061360 # D1210 - SENSOR, OUTSIDE AIR TEMPERATURE - REPLACE 30013 miles
05/29/2001 061360 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 30013 miles
05/29/2001 061360 # L3502 - FUEL SEAL, AND /OR PUMP ASSY RPL 30013 miles
05/29/2001 061360 # N3615 - BLADE WIPER RPL 30013 miles
05/29/2001 061360 # E7620 - STEERING SHAFT LOWER BEARING REPLACEMENT 30013 miles
05/29/2001 061360 # Z7902 - 2-DAY COURTESY TRANSPORTATION 30013 miles
05/29/2001 061360 # B7240 - HEADLAMP BEZEL REPLACEMENT 30013 miles
03/22/2001 058221 # F2143 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 28097 miles
03/22/2001 058221 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 28097 miles
03/22/2001 058221 # K7121 - PUMP, TRANSMISSION OIL - R&R OR REPLACE 28097 miles
02/23/2001 056934 # K7251 - INPUT HOUSING AND TURBINE SHAFT ASSEMBLY - REPLACE 27911 miles
01/09/2001 054755 # L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT 27764 miles
01/09/2001 054755 # T2020 - TOWING 27764 miles
08/11/2000 048368 # C0130 - FRONT SIDE DOOR WINDOW OUTER SEALING STRIP REPLACEMENT - R 25989 miles
08/11/2000 048368 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 25989 miles
08/11/2000 048368 # R0940 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - RIGHT - REPLAC 25989 miles
08/11/2000 048368 # C9020 - DRIVER OR PASSENGER SEAT BELT BUCKLE REPLACEMENT 25989 miles
08/11/2000 048368 # N0110 - BATTERY REPLACEMENT 25989 miles
08/11/2000 048368 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 25989 miles
06/15/2000 046002 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 25228 miles
06/15/2000 046002 # C9040 - DRIVER OR PASSENGER SEAT RETRACTOR SIDE BELT REPLACEMENT 25228 miles
06/15/2000 046002 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 25228 miles
09/09/1999 033333 # C7051 - COVER AND/OR PAD, FRONT SEAT BACK CUSHION - LEFT - R&R OR 18746 miles
09/09/1999 033333 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 18746 miles
04/05/1999 026092 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 11219 miles
04/05/1999 026092 # N3620 - W/S WIPER ARM RPL 11219 miles
03/17/1999 151932 # N4800 - BODY CONTROL MODULE REPLACEMENT 10092 miles
03/15/1999 151691 # N3700 - HOSES, NOZZLES, WASHER AND/OR WIPER STOPS - WINDSHIELD - R 10008 miles
03/15/1999 151691 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 10008 miles
03/15/1999 151691 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10008 miles
12/02/1998 W16599 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 4161 miles
12/02/1998 W16599 # Z7902 - 2-DAY COURTESY TRANSPORTATION 4161 miles
12/02/1998 W16599 # C1013 - WEATHERSTRIP - ROOF - REAR - ALIGN OR REPLACE 4161 miles
11/13/1998 W15542 # R3011 - KEYLESS ENTRY TRANSMITTER REPLACEMENT 2142 miles
10/13/1998 A08391 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1686 kg (3718 lb) Order Number : 143FV6
Build Date : 10/07/1998
OPTION CODES
AAB AK5
AR9 BGR
B34 B84
CF7 CJ2
DL5 DL8
D42 FE3
FE9 G90
G92 IP3
JL9 K63
LS1 MX0
M30 NF2
NK4 N37
QD4 R8T
R9U T82
T96 UL0
UV6 UV7
UZ6 U1S
U52 VM3
V49 V73
XGG YGH
Z51 1AY
1SA 11U
19I 193
For some reason, all 99 models come up codes only, click This LINK. This will tell you what the codes are.
thaitime
thaitime
This is the list for the entire claim history for my 2001 Vert that I got when it was run for me by Gene Culley:
09/18/2002 255208 #J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 24942 miles
03/21/2002 233237 # L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT 19422 miles
03/21/2002 233237 # Z7901 - 1-DAY COURTESY TRANSPORTATION 19422 miles
02/07/2002 228437 # C1061 - FRONT SIDE DOOR WEATHERSTRIP REPLACEMENT - LEFT 16895 miles
02/07/2002 228437 # E0037 - CAP, WHEEL CENTER - ALL - REPLACE 16895 miles
08/14/2001 207998 # N0110 - BATTERY REPLACEMENT 12908 miles
08/14/2001 207998 # Z7901 - 1-DAY COURTESY TRANSPORTATION 12908 miles
8/14/2001 207998 # T2020 - TOWING 12908 miles
02/01/2001 185799 # N2388 - SWITCH - REAR COMPARTMENT - LID RELEASE - REPLACE 8570 miles
08/02/2000 A01979 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE Warranty Start Date : 11/16/2001
Delivering Dealer : LOU BACHRODT CHEVROLET
1801 W ATLANTIC BLVD
POMPANO BEACH , FL 33069-2799
(954) 971-3000
CLAIM HISTORY
01/26/2006 087740 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 8800 miles
10/29/2001 A11770 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CF7 - REMOVABLE SUN ROOF C60 - AIR CONDITIONING
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED OUTSIDE REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - REAR AXLE 3.42 RATIO IP3 - INTERIOR TRIM DESIGN
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL QG1 - PAINTED ALUMINUM WHEEL
SLM - STOCK ORDERS UN0 - AM/FM STEREO W/CD PLAYER
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SA - CORVETTE COUPE BASE EQUIPMENT GROUP
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
21U - ELECTRON BLUE METALLIC
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2007 CORVETTE COUPE Warranty Start Date : 04/02/2007
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : KERBECK CADILLAC PONTIAC CHEVROLET, INC.
430 N ALBANY AVE
ATLANTIC CITY , NJ 08401-1315
(609) 344-2100
CLAIM HISTORY
03/26/2007 A31276 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1697 kg (3742 lb) Order Number : KTRTG9
Build Date : 03/26/2007
OPTION CODES
AAB - MEMORY PACKAGE AG2 - 6 WAY POWER PASSENGER SEAT
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AQ9 - ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS BGR - BOWLING GREEN PLANT
BS1 - INSULATION ACOUSTICAL PKG CF7 - REMOVABLE ROOF PANEL
CJ2 - DUAL ZONE, ELECTRONIC A/C DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV D42 - LUGGAGE SHADE & PARCEL NET
E2C - ORDER TO DELIVERY - EXPEDITE FE3 - SPORT SUSPENSION
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IL6 - TRIM INTERIOR DESIGN JJA - PT DRESS SUBASSEMBLY
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT J55 - HEAVY DUTY POWER BRAKES
KA1 - HEATED SEATS KNP - TRANSMISSION OIL COOLING SYSTEM
KPS - COOLER OIL, ENGINE K63 - 110 AMP GENERATOR
LS2 - ENGINE, 6.0 LITER 400 HP MN6 - TRANSMISSION, 6-SPEED MANUAL
MZ6 - 6 SPD MANUAL TRANSMISSION NK4 - LEATHER WRAPPED STEERING WHEEL
NT7 - EMISSION SYSTEM FEDERAL TIER 2 N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QX3 - CHROME ALUMINUM WHEELS R6K
R6M - NEW JERSEY SURCHARGE R6P - PREMIUM TINTCOAT PAINT
R9K - WHOLESALE FLOORPLAN PLUS R9N - TWO-TONE SEATS WITH EMBROIDERY
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
UE1 - 1 YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE) UG1 - UNIVERSAL HOME REMOTE
UJ9 - LOW TIRE PRESS. INDICATOR UK3 - STEERING WHEEL CONTROLS
US3 - ANTENNA DIVERSITY UV6 - HEAD-UP DISPLAY
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. U3U - AM/FM STEREO, CD PLAYER, DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES (REPLACES 6-DISC IN DASH CD W/SINGLE DISC CD)
U52 - ELECTRONIC INSTRUMENTATION U65 - SPEAKER SYSTEM 7, PREMIUM
VA5 - ENGLISH LANGUAGE LABEL VDD - VEHICLE INFORMATION DVD
VK3 - FRONT LICENSE PLATE BRACKET V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XND - FRONT TIRE - P245/40ZR18 YTK - REAR TIRE P285/35ZR19
Z51 - Z51 PERFORMANCE PKG (INCLUDES:LARGER CROSS-DRILLED BRAKE ROTORS,PERFORMANCE-TUNED: TIRES, STABILIZER BARS,SPRINGS, SHOCKS, GEAR RATIOS) 1SZ - PREFERRED EQUIPMENT SAVINGS
3LT - 3LT PREFERRED EQUIPMENT GROUP AM/FM STEREO, 6 DISC CD CHANGER, MP3 PLAYER, BOSE PREMIUM 7 SPEAKER SYSTEM, XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. (REPLACES STD/OPT/PKG RADIO) HEAD-UP DISPLAY PWR TELESCOPING STEERING WHEEL HEATED SEATS INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS DRIVERS MIRROR, WITH AUTO DIMMING MEMORY PACKAGE UNIVERSAL HOME REMOTE SIDE IMPACT AIRBAGS, DRIVER AND PASSENGER SEATS, ADJUSTABLE SPORT BUCKET W/PERFORATED LEATHER INSERTS POWER SEAT ADJUST- PASSENGER, 6 WAY LUGGAGE SHADE & PARCEL NET STEERING WHEEL RADIO CONTROLS 31I - LT CASHMERE INTERIOR TRIM
316 - CASHMERE 83U - ATOMIC ORANGE METALLIC TINTCOAT
