a/c help
Old Jul 18, 2010 | 07:56 PM
ls2 dude's Avatar
ls2 dude
Default a/c help
so my a/c is blowing warm but randomly today it blew cold for ten or fifteen minutes. i stopped and got a pressure gauge on the low side its reading very high(no numbers just deep into the red). i then looked to see if the compressor would kick on and it is not. what should i do next. i cant charge the system because the pressure is to high.
Old Jul 18, 2010 | 08:53 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
It's reading high because the compressor isn't running. Unhook the battery for a minute or so, then hook it back up. This will reset the pressure switch.
Start the car, turn the A/C on max, hook a can of refrigerant up to the low side, and see if once it sucks some freon into the system, the compressor kicks on.
If you need some more info, PM your number and I'll try to help you out.
Old Jul 19, 2010 | 07:49 PM
ls2 dude's Avatar
ls2 dude
bump i tried the above method it did not suck in anything. the pressure gauge was still at max. any other ideas thanks
Old Jul 19, 2010 | 08:54 PM
sneakelman's Avatar
sneakelman
What codes is the DIC throwing? That's a good place to start.
Old Jul 21, 2010 | 12:15 PM
ls2 dude's Avatar
ls2 dude
po333 and po338 are the codes those are the inside and outside tempurature sensors when i reset it po333 stays and po338 comes back after a while. also the air temp on the hvac is reading 69 degrees all the time
Old Jul 21, 2010 | 12:55 PM
bigleman's Avatar
bigleman
It is your outside temp sensor.
I had the same problem. If i remember right, it was a $5 part (yet a $20 harness )
They get water in them and it gives the A/C false readings causing it to malfunction like that.
It is a typical issue. Cheap and easy fix to something overly complicated!
Be glad it isnt an expensive and difficult fix to something stupidly simple like everything else!
Old Jul 21, 2010 | 03:42 PM
ls2 dude's Avatar
ls2 dude
sweet no can you tel me where this sensor is located lol iv also noticed people with that problem have there ac light flash and then cut off mine just stays on
Old Jul 21, 2010 | 04:18 PM
ls2 dude's Avatar
ls2 dude
Although my sensor is bad. From the cases iv seen the ac wont turn on when the sensor reads 38. From the ones i see stuck on 69 people say the ac works fine its just an pain in the ****. Im lost and this is pissing me off. The compressor does not come on and the codes stated above are the only ones i have. i will replace the sensor and wire anyway however i do not think it is the culprit.
To a/c help
