Service Active Handling - Code? Help
Old Jul 18, 2010 | 10:15 PM
Tino's Avatar
Tino
Default Service Active Handling - Code? Help
This winter I forgot to attach my battery tender and the battery went dead. I charged it and the car started right up no problems, but since then I have been getting this intermitent "Service Active Handling" code. The dealership told me that they did a scan and everything is okay. Not sure why I keep getting this message.
Does anyone else have this problem? Any help would be greatful.
Many Thanks Tino
Old Jul 19, 2010 | 11:13 PM
Tino's Avatar
Tino
Anyone?
Old Jul 19, 2010 | 11:27 PM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
My car has been getting the dreaded Active Handling message. It comes and goes, there are lots of write ups on this in the tech section. Normally the BPMV that is mounted in front of your power steering pump is starting to fail. Its a common problem for these cars. Hope this helps.
Marc
Old Jul 20, 2010 | 06:07 PM
Tino's Avatar
Tino
Marc
Thx Marc,
I took it back to the dealership today as it was just diagnosed on June 21st as my extented warranty just expired then. They said that since I had reported it in June they would still honour any repairs it would need. My tech advisor said they would check it out and update the software?
Keep you posted
Old Jul 24, 2010 | 01:13 AM
Tino's Avatar
Tino
Got it back and all is well. They replaced the EBCM and did a software update.
Tino
Old Jul 24, 2010 | 02:17 AM
00Corvette's Avatar
00Corvette
Check the codes.
press and hold number 4 and simultaneously press number 1 four times to enter diagnostic mode. Look for the codes listed under "TCS"
Old Jul 25, 2010 | 10:10 PM
Tino's Avatar
Tino
Originally Posted by 00Corvette
Check the codes.
Thanks for the tip Don
Old Jul 25, 2010 | 11:37 PM
Toms02C5's Avatar
Toms02C5
Tino
You're lucky they picked up the tab - just replaced mine for $1,100 (and that's getting the EBCM from Gene Cully)
Old Jul 26, 2010 | 12:26 AM
Jistari's Avatar
Jistari
For those who may not know, if it is the EBCM that goes you can have it rebuilt by a place like Absfixer for less than $200 and they warranty the work.
Old Jul 26, 2010 | 01:14 AM
00Corvette's Avatar
00Corvette
No prob. Also, for codes like that one...a cool feature is you can check tho codes while your driving...so if it's the type of code that only pops up while driving and then disappears (although it should still show the H code) you can still diagnose.
To Service Active Handling - Code? Help
