Parking light issues
Old Jul 19, 2010 | 03:21 PM
v8ophile's Avatar
v8ophile
Default Parking light issues
I can't seem to get my parking lights to come on when they're supposed to. They don't come on in the parking light position or the headlight position. The headlights function just the way they should: low beams come on in headlight position, highs and lows come on in high beam position, both turn off but remain in the 'up' position when taken back to parking, and then retract when taken back to off. Is this a bad switch or relay? All the parking lights come on when I unlock my car with my fob, so I don't think it's a blown fuse, and I checked all the connections on the headlight control module. Do you know where the relay is located that controls the parking lights? Is this possibly a bad switch in the stalk? Thanks
Old Jul 19, 2010 | 09:08 PM
Toolmandbq's Avatar
Toolmandbq
Had the same problem with my vett. It was a bad switch. Did the repair found under headlight switch failed. Sorry, I done have the link handy. The repair took about 1 1/2 hours and it works well.
Old Jul 27, 2010 | 11:30 PM
v8ophile's Avatar
v8ophile
Thanks for the tip. I found the thread you mentioned and was able to fix my problem. Saved some $$$!
Old Jul 28, 2010 | 12:18 PM
Any possibiity of posting up the thread link you used? Others may want to reference it.
Old Jul 28, 2010 | 01:33 PM
UM Rebel's Avatar
UM Rebel
Mines worked that way from the day I bought it! Thought the Corvette gods decided that's the way it was supposed to work
To Parking light issues
