Recovered Lower Door Panel (PICS) Tutorial/Write Up/How to
I saw one advertised at the same store that people are buying the cheap aluminum jack from...............
The welders really aren't that complicated either and are basically a heating element with a flute to feed in a filler material rod. For this project you could replicate the tool by heating anything made of metal and once hot enough, using that metal object to work/melt the plastic back together. There's a pic of the end of a typical plastic welder so you can see what I am talking about, pretty basic.
To better answer your question, yes you could reweld it back together. Depending on the separation process there should be enough of the plastic nubs left to simply re melt and get a decent hold. No, I would not buy a special tool to do this. Any object hot enough to melt plastic will do the job. I went with the method I chose because I have a way of "over engineering" things and wanted to make sure they never came apart
P.S. Bookmarking this thread also
It was a cold winter project that kept my mind off the weather...anyway, here's some more detail. After separation I dremeled down the remaining plastic posts and smoothed all surfaces that would touch each other, then applied industrial strength Velcro in long strips test fitting as I went along. I had to make sure the lower panel did not protrude away from the upper panel because of the added material at the interface...it worked fine. The ends were a bit more difficult, but it just takes a little more fine tuning to get them tight. Also, I went right over the existing vinyl with my Alcantara and got excellent results using a glue gun (don't even try to staple it like the OEMs...staples will fall out later and you will be pissed and end up with the glue gun afterall). I spent at least 30-40 hours off and on doing this mod...part of the time off was waiting for my fingers to heal up from burns, cuts, etc. I used just 1 yard of material and did the center console cover and the lower door panels...with lots left over for next winter. Also, I picked up a beat up (Katrina soaked) door panel on the bay of E to practice on first...this really helped and I got my $$$ back reselling the red reflector and speaker screen.
Here's the end result...
http://forums.corvetteforum.com/c5-g...-makeover.html
When I made this thread I was hoping others would post up with different methods so that other readers could see some options, thanks for doing so. Velcro is a great idea that I didn't think of. I was going for the more permanent attachment for mine, like the factory. Good to hear yours worked out, any pics?
As an auto body technician I have grown to hate plastic welders over the years and do everything in my power to avoid using them. I don't think they work very well and also the whole process of plastic welding is very dependant on the type of plastic and it's properties. The term "plastic welding" is also very misleading because you really aren't making two pieces into one like when you weld metal. Rather you are more or less "brazing" two plastic pieces together with a filler material.
Hahaha ya I know. That part is easy...
Step 1. Send trim panel to Apsis
Step 2. Open wallet
That is a crazy hard area to do because of all the contours and such and it would require multiple pieces sewn together. Apsis does amazing work and that part should be left to the pro's.[/QUOTE]
You are right in that they do great work but its hard to justify almost 2k for door panels!!
