Question - Active Handling Repairs
Old Jul 23, 2010 | 12:42 PM
LoveLee's Avatar
LoveLee
4th Gear
Default Question - Active Handling Repairs
Just Curious...my active handling just registered a "get serviced soon" reading and was wondering what I'm looking at for repair costs. Ball park of course since the car's warranty is up. Thanks!
Old Jul 23, 2010 | 12:45 PM
Blew by you's Avatar
Blew by you
I just paid $525.00 for the steering wheel position sensor, it was one of the codes from the Service Active Handling Soon, good luck!.
Old Jul 23, 2010 | 02:34 PM
LoveLee's Avatar
LoveLee
4th Gear
Thanks...that's better than I thought it would be! I didn't even think about there being more than one thing possible applying to that message...maybe it'll be less.
Old Jul 23, 2010 | 04:26 PM
Jistari's Avatar
Jistari
It comes up a lot here and yes it could be for a great number of reasons, some easey to fix and inexpensive and others that can be more involved.
One of the first things you should do is read the trouble codes set in the system....follow instructions in this link
http://forums.corvetteforum.com/c5-g...post1563436976
Clear whatever is there, use the car and check what codes are current.
Look up the source for whatever codes you are showing here
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Then you will have a much better idea of what is wrong and what it might cost to fix.
Many times these codes are set not necessarily due to a bad or malfunctioning part but due to either low voltage (like a bad battery) or a bad ground to one of the components in the AH/TCS system.
Sorry, away on vacation atm so I dont have my saved links, but you should find a good post by bill about how to correct voltage/bad ground issues.
Thats where Id start.
Good luck
Old Jul 23, 2010 | 07:02 PM
RJRSW's Avatar
RJRSW
Where did you have the work done?
I had the code set once for the steering wheel position sensor but just unplugged and replugged the 4 pin connector on the sensor about 4 times and it never came back again.
I had checked with Watson Chev in Tucson when I got the code and they quoted me a total cost for both parts and labor of just under $350 if it needed to be replaced.
To Question - Active Handling Repairs
